Wing Strut attach fitting A-A11 Inspection results
    Re: Wing Strut attach fitting A-A11 Inspection results
    Rob is correct I have offered the same and some have called me with results too! Rob , e-mail me direct with any reports on the UK later model s
    F-22's the FAA understands there has been a strut problem over there. how about. the attach fittings too! I read yours, are there others?
      Forrest: The FAA might believe there is a strut problem here because of the "volume" of transatlantic airfreight on new struts. The FAA can keep their knickers on, however. With the £/$ exchange rate as it is, it's just easier & cheaper for us to get new.
      There are two F22's in the UK. The one at my field (tailwheel), the struts passed OK, but the fitting has not yet been formally inspected (although it will pass just fine).
      The other F22 (nosewheel)...I have no idea about.
      The one UK F21 is demolished after an accident.
      The one UK F19 has new Airframes struts, and I know not the results of the fitting inspection (I will ask about this one and the other B models too).
      All the other UK Taylorcraft ar B or Military models.
      Hope this helps.
        1946 BC12D/19 N43336 ser#6995 SB#2007-002 CW by boriscope/visual inspection. No corroison found. Aircraft is float equipped and has spent time in Alaska. Airframe TT1700, Seaplane time less then 100 hours.
        Joe
          1946 BC12-D N1199V (originally N95896) S/N 8196. 2052.7 total airframe time.(Converted to BC12D-4-85 via STC SA-210 in 1997) Never on floats or skiis according to logs. Inspected attach fitting A-A11 as per SB2007-002. No corrosion found in any areas. Note: lift strut bolt and landing gear were completely removed when this inspection was accomplished.
          1946 BC12-D N96337 S/N 8637. 1600 total airframe time. (converted to BC12D-85 in 1971 via STC SA-210) 363.6 hours float time in 1946-1947 27.7 hours on skiis in 1988. Inspected attach fitting A-A11 as per SB2007-002. No corrosion found in any areas. Note: lift strut bolt and landing gear were completely removed when this inspection was accomplished.
            I never thought about the volume to the UK , that may explain the comments I got from the FAA , they can get their knickers all bunched up at times. thanks for that report!
              More UK results:
              G-AKVO is 1946 BC12D, Ser no: 9845 , N44045, around 3000 hours total time. No record of floats or skis but believed never fitted due to USA Arkansas location. Full fitting SB carried out with strip to bare metal and checked with tv boroscope and magnifying glass by inspector. Absolutely no corrosion. cracks or pitting found. Fitting primed and repainted, and centre lug treated with ACF50, and struts re-attached.
                Hello Forest,
                Thank you for collecting the inspection results and forwarding them on to the FAA contact.
                Inspection was done on N96175, BC12D during January strut inspection routine, SN 8475 and no abnormality was detected as per SB NO. 2007-02.
                Surface areas were cleaned, inspected, primed and protected as per SB instructions by A&P/IA. Further, the 4 struts passed inspection for the AD with flying colors. This aircraft has not been on skies or on floats in the 1600 hours TT.
                  Taylorcraft BL-65, 1939 NC22211 Serial #1149. Landplane only, inland based, approx. 1700 hours total time. Only outside tie down known was 10 years in the 70's. In storage before and after for about 30 years. Inspected the lift strut attach fittings per the SB, with the exception of borescoping the interior. No cracks or corrosion found. Since the plane is under restoration, will fully comply with the SB (borescoping) in the near future, including logbook entry. Still, wanted share the results so far.
                    Re: Wing Strut Attachment Fitting A-A11 Inspection Results.
                    1946 BC-12D G-BRXE N95059 Ser # 9459.
                    No record of being on floats or skis.
                    Cleaned and inspected as per SB No. 2007-002. No cracks or corrosion found. Repainted.
                    New sealed struts fitted as per AD.
                    Bruce Morgan.
                    TF No. 35515593
                    Forest of Dean, UK.
                      1946 BC12D 65 hp N43972 s/n 7631 tta 2137 hours
                      on skis from time to time
                      probably NEVER hangared, always stored outside
                      fitting inspected per service bulletin using borescope, no cracks, paint blisters or rust, fabric is normally cut back from fitting to allow ventilation, been that way forever, drain holes were clear
                      not a surprise since this aircraft has had these fittings reinforced with a complete fitting overlay of formed 4130 sheet, essentially doublng the thickness as a result of cracks found circa 1992
                      Andy McAnaul was informed of this and was sent the 337 and sketches for this repair back in the fall of 2007
                        BC12D S/N 6628 N39969, complied with bulletin 2007-002, when all four struts were replaced with Univair struts. This plane sat idle for ten years ,and was rebuilt in 1989, never on floats. Low time airframe less than 1200 hours, no apparent corrosion. The rear struts failed the eddy current inspection. I cut one apart , it looks as strong as new. I will ship the small part to you.
                        Walter Hake TF#
                        • #27
                          Eddy current is for CRACKS!!!! EVERYBODY LISTEN UP!! Eddy current is for CRACKS!!!!
                          Nothing personal Walt. The rant isn't directed at you. Just frustrated with this whole mess and thinking about a cut up strut with an unconfirmed crack and no corrosion ruined needlessly. If it had been my strut and I got an eddy current indication from the old requirement I would have followed with a dye penetrant test to locate the crack and seen if a simple weld repair would fix it. Of course I would have followed the whole process with an x-ray and ultrasonic or visual for the corrosion we are all looking for. The old requirement for eddy current WON'T FIND CORROSION. For everybody else out there, DON'T USE EDDY CURRENT TO LOOK FOR CORROSION. IT WON'T WORK!:doh:
                          • #28
                            1946 BC12D N95345 S/N 9745 Removed struts and took them to Stork Twin City Testing. St. Paul Minn. $200.00, 1 hr while I waited, no rust or cracks. He said as good as new. SB 2007-002 complied with as per instructed. Found clean and no cracks or corrosion. I have owned his aircraft for 34 years always hangerd. No floats, it may have been on skies before I got it This aircraft is my pride and joy and is very well taken care of.
                            Gerald Buffington A&P FAA, DME .
                            • #29
                              Atta boy Hank!! Forrest has been the same way over the phones the last two days. frustrated! OWNERS for cripes sake get the latest AD's & Service Bulletins and consult with Your IA , then form a plan and do it.
                              One old boy pulled his struts apart ( on purpose) to prove the structual integritary and then repaired them. YES if you find lower end corrosion , they can be repaired IAW the FAR's. hang in there the NPRM on the A-A11 fitting is due soon.
                              • #30
                                Hank, thanks for your comments, I cut the strut for my own curiosity, I gave the other three struts to a deserving person who will carefully follow through, with your comments.
                                Walter Hake TF#
