Wing Strut attach fitting A-A11 Inspection results
  • Wing Strut attach fitting A-A11 Inspection results
    The Revision for the Attach fitting inspection SB 2007-002 issued Nov 8th, 2007 will have a new importance shortly.
    I am asking all members who have complied with the inspection per the SB posted on Taylorcraft web site:
    to please post any results and comments here, use your Model #, N-Number, and ser# of your Taylorcraft. Please include any usage on land, floats and or skis , hours and times if possible. Please use BRIEF comments.
    The first reply will be mine and will use proper format. This will soon have furthur action by the NTSB & the FAA they have to insure for safety purpose that it will be a mandatory inspection ( known as a AD) do not shoot the messenger, there will be a commenting period and this data may help the outcome of the pending AD especially the usage.
    Re: Wing Strut attach fitting A-A11 Inspection results
    1946 BC12D , N43533 , ser# 7192, ski equipped approx 20 hrs over last 15 years. Never on floats.
    Inspected per SB No. 2007-002, used visual and borescope, treated as described after inspection. Found usual dirt , no unusual corrosion or debris. Cleaned and treated as described in AD . returned to service. per log book entry of A&P , IA . dated: Nov 23rd, 2007.
      1940 bc65 n26658 ser#2000 strut atttach fitting inspection was completed on 11/10/07 pryer to installing lift struts after complyence with ad 2007-16-14 NO crostion or cracks were found air craft was returned to service by a/p a/i on 11/10/07
        1946 BD-12D, N43752, S/N 4711. Strut fitting inspection performed in compliance with SB 2007-002 prior to reinstallation of struts using visual and borescope inspection. No problems found and fitting corrosion treated in compliance with AD. Aircraft returned to service after A&P/IA sign off dated January07/2008.
        Aircraft never on floats or ski's, and always hangered. Strut ultrasound inspection on November 26, 2007 also negative for any problems, struts corrosion treated prior to reinstallation.
          Just cut and pasted part of my logbook entry........
          Airplane has never been on floats.
          I also went ahead and did part 2 and stripped and painted it. I figure I've done all I can that way, and when it was apart and easy. Unless the AD comes up with a repetitive interval or cut off the fittings and replace them, I won't have to screw with them again untill his 4 years on the struts runs out.
          Airframe:
          Date: 12/10/2007 Tach: 684.3
          Tail #: N96774 Make: Taylorcraft
          Model: BC12-D Serial #: 9074
          ACTT: 684.3
          1. Complied with Taylorcraft Service Bulletin 2007-002. Inspected fittings with struts, attach bolts, and steps removed. Cut edges of fabric to gain unobstructed access to left and right strut attach fittings. Inspected fittings visually and with a 1/4” flexible lighted borescope with 90˚ mirror in accordance with Section 1 of the Service Bulletin. No blistered paint noted on either fitting. Stripped both fittings and adjacent tubing to bare metal. Inspected and found no corrosion, cracks or pitting showing previous corrosion on either fitting. Treated both fittings and adjacent tubing with 2 part green epoxy primer and 2 coats of Tennessee red 2 part enamel paint. After primer and paint dried, verified drain holes were open an unobstructed. No fabric patch was necessary around either strut fitting. No further action required.
            Only thing I wish I had at the time, was the camera adapter for my borescope. Could have taken pictures of the inside and put them in the logbooks. That way if he moves to who knows where and someone else has to look at it when the AD comes out, they wouldn't have to take my word for it. That airplane looked fine, and other than trimming some pinked edges of fabric it was open and free to drain if water had found a way into the fittings.
            CJ
              Date: 1/19/08
              N96325
              Serial #: 8625
              Model: BC-12D
              Tied down outside for last 20 years or more. Never on floats.
              Inspected per SB No. 2007-002, used visual and borescope, treated as described after inspection. Found no sign of any corrosion. Cleaned and treated as described in AD. returned to service per log book entry of A&P , IA . dated: January 19, 2008
                Keep them coming, talked with Andrew McAnaul, the FAA engineer, this afternoon. He feels this will be VERY useful and we do intend to follow up with a similar strut inspection data base. ( using what is already there and expanding it) Keep this one for the attach fitting.
                I truly believe we can extend the four years on the struts with proper documentation and data. Went out for pizza and found many have posted to this thread. Keep it up. He is very interested in the USAGE of the aircraft. Obviously the float ships will be watched very carefully.
                  1946 BC12D/19 N43624 ser#7283 SB#2007-002 CW by boriscope/visual inspection. No cracks or unusal corosion found. Did find light corosion inside fitting. Cleaned and treated. Airframe TT-4600, float equiped, also lived in Alaska (salty) for many yeare early in it's life. No record of fittings beeing replaced.
                    Aeroplane 1:
                    1946 BC12D , G-BREY (N43640) , ser# 7299, Never on floats or skis.
                    Inspected per SB No. 2007-002, treated as described after inspection. No unusual cracks, corrosion or debris. Cleaned and treated as described in AD . returned to service.
                    Aeroplane 2:
                    1945 BC12D , G-BRPX (N39208) , ser# 6462, Never on floats or skis.
                      After the strut AD my AP/IA does not want to do anything other than a visual inspection with the strut fitting until a DEFINITE AND FINAL AD is released. Obviously if we look at it and see a safety issue, we will take it out of service but that is unlikely on a landplane (never on skis or floats) that has been hangered since its restoration.
                      I will post once we know something. When is the AD to be issued so we can review it?
                      Thanks for the update Forrest! Hopefully with people for you working closely with the FAA this one will be clearer and more reasonable from the beginning.
                      Brian
                        How can I make it any clearer, do the inspection per the SB........ I believe that will comply with the AD ( if there is one).
                        I am 90% it will comply, I am 99.9 % it will become an AD...... soon!!
                        Please keep this thread for data input......
                          1946 BC 12D N622SE, Ser.#10786, never on floats or ski’s, completely restored in 2003 and always hangared. Struts were removed and strut fittings were cleaned and inspected per S B 2007-002. No cracks or corrosion found. The fittings were primed and painted as described in the A D. New struts installed and aircraft was returned to service by A&P on Nov. 29, 2007.
                            If anyone has any failure against this SB, but is reluctant, unwilling or unable to post the results of the failure, then may I offer the following service?
                            PM me (or email me) the results, and I will then post them under my name, with all names, serial numbers and N numbers "disidentified" so as to ensure anonymity from the source.
                            I think it is important that any failures are known about, even if it means a bit of jurisprudence to protect the identity of airplane & owner.
                            If that is still not good enough for some, then it may be an idea to email Andy McAnaul at the FAA directly, with a request for anonymity.
                            robert.lees "at" taylorcraft.org.uk
                              1040 BC-65. No record of being on floats or skis. No corrosion found in attach fittings when lift struts replaced with new sealed ones per the AD.
                              Dan Brown
                              1940 BC-65 N26625
                              TF #779
                              Annapolis, MD
