When we did the mags, on my plane, I was told that turning off the mags at idle was bad for the mags, on all other aircraft I've flown you pulled the mixture knob to lean and starved the engine till it quit.
this didn't work on mine, and according to the carb shop it never will.
another A&P says the carb should be set to kill the engine when pulled to idle or pulled fully back, which doesn't make sense, I personally like the stop and the engine just purrs on at 400 rpms. I would be concerned to pull the throttle too far back and end up with a deadstick landing
So what is it, I would like to know I'm on the final repairs and should be soloed by christmas.
