Im replacing my magnesium aileron bracket with pre war steel brackets, the magnesium brackets have a phenolic cable guide attached to them, the pre war do not . My IA wants to know if it is ok not to have a guide as the magnesium brackets do . Any help would be appreciated.
Pre war aileron brackets
Re: Pre war aileron brackets
At the very least I think you'll want some form of rub pad on top of the hinge. The cable runs are long and not that much cable tension so it is likely the cables will contact the hinge. An alternative may be to add support for the cable at one or more of the ribs.Scott
Dr. Tim do you have those AOI numbers? Did they change the wing to fuselage mounts to achieve that?Originally posted by astjp2 View PostAngle of incidence is also different between pre and post war airplanes which may affect cable position, but I have not actually verified it myself. Tim
The info I've read so far was 3.8* AOI which was the best L/D ratio for the 23012 airfoil in the 1930's according to NACA documents. Maybe Taylorcraft decided to change but I suspect ?. Please convince me.Originally posted by astjp2 View PostGary, not off the top of my head, search on the forum for the real numbers. Tim
Hope all is well with you and your family. Alaska awaits your return Tim.
