Shinn Wheel Washers
  • Shinn Wheel Washers
    Hi All
    Looking for information/photos of the Shinn wheel/axle break-out.
    The Taylorcraft parts manual shows two washers inboard of the inboard wheel bearing, and two washers outboard of the outboard wheel bearing, one of which is the tab washer directly under the nut.
    I'm guessing one of the washers is actually a spacer that puts the wheel in the right location on the axle and the other two are dust/grease shields?
    Be a while before I need them but I appear to be missing some parts. I have the two tab washers, and I think I have one of each of the inboard and outboard dust washers. Missing the inboard spacers and two dust shields I think.
    Would be a great help if I knew what these parts look like.
    thanks
    Re: Shinn Wheel Washers
    Scott,
    When I ordered some replacement parts for Shinn brakes, Skybound sent me a photo breakdown of all the parts and their part numbers. Since they are the ones that have the parts as well, give them a call: 1-770-446-6797. They are in Doraville, Georgia.
    Charles
      Hi All
      thanks
      It is not a spacer, just a thin shield washer.
      I have only ever seen one there inboard of the inboard bearing.
      However they are so thin that I doubt that two would cause any harm.
        There is a thin washer to keep the brake mounting screws from backing out, and a dust shield that goes in the wheel.
          that makes sense, I hadn't realized they were the two items that were in play
            Hi All
            Looking for information/photos of the Shinn wheel/axle break-out....
            thanks
            What is a "Break Out"?
              An exploded view or diagram.
                So like an IPC (Illustrated Parts Catalogue)?
                  ...brake mounting screws ...
                  As an aside, the brake mounting screws are NOT the usual AN type. They have a different countersink angle.
                    so are they 82* instead of 100* countersinks?
                      This info is from a posting quite a while back...from Rob Lees:
                      The brake plate assembly is screwed to the gear leg using unusual 82 degee countersunk screws.
                      It would appear that the original slotted screws are not available, but I found a source of
                      cross-head screws in stainless from an approved source.
                      The part numbers for the approved, stainless structural countersunk screws is
                      MS51960-65 (or 10-32 UNF-2A x 1/2 PH FLT HD Machine Screw)
                      They are available from:
                      Alabama Aerospace Div,
                      102 Skylab Drive,
                      Huntsville
                      AL 35806
                      Phone (256) 851 9005 or toll-free (800) 448 1877
                      Fax (256) 851 1988
                      A NASA-approved supplier, Alabama Aerospace (a Birmingham Fastener company), sources reliable specialty fasteners for aerospace and defense.
                      Dick Smith
                      Dick Smith N5207M TF#159
                        You might check this link: http://www.amazon.com/WBParts-Expres.../dp/B00UY5ZIHQ
                        Dick Smith
                          I've got a bag of those screws, had to order 100 to get what I wanted. They are the correct ones for mounting the brakes.
                            I would be happy to buy a couple of dozen from you.
                            I think I probably have the spacers/washers, I just don't know what they look like. The parts manual definitely shows two "washers" inboard and two outboard. My wheels show previous damage consistent with someone neglecting to install at least one of the inboard washers ie the wheel casting contacting the brake mount/mechanism.
                              I will look for the bag at the hangar today and PM you later, Scott.
