Rib nails
  • Rib nails
    What does everyone use for nails attaching the aluminum ribs to the wood spar on the Taylorcraft., So far, I've only been able find 14 ga X 3/4" used on the Citabria and champs etc. The rear spar on the Taylorcraft is only 5/8", is there a source for 1/2" spar nails?
    Bob Picard
    Bob Picard
    N48923 L-2B Skis/Wheels
    Anchor Point, Alaska TF#254
    These are the only tiny nails I could find...13 mm equals .51 inch.
    https://www.amazon.com/dp/B08JSFH3JR...xpY2s9dHJ1ZQ==
    https://www.micromark.com/Model-Rr-Nails-1-2
    I checked all the aircraft suppliers and could
    n't find the 1/2 inch size.
    Dick Smith N5207M TF#159
      Aircraft Spruce has the following nails:
      an301-20-2 1/4"
      an301-20-3 3/8"
      an301-20-4 1/2"
      an301-20-5 5/8"
      an301-20-6 3/4"
      an301-20-8 1"
      These are shown in catalog
        I used various lengths of cement coated nails from Aircraft Spruce. But just check the website and they don't appear anymore.
        there's a lot of this going around!
        This is what you're looking for anyway:
          Don't use the same nail holes in the ribs (unless you have new spars)
            an301-20-2 1/4"
            an301-20-3 3/8"
            an301-20-4 1/2"
            an301-20-5 5/8"
            an301-20-6 3/4"
            an301-20-8 1"
            Thanks for the info. That must be an old catalog. The current catalogs no longer list any AN 301 nails of any size.
            Bob Picard
              No problem, new ribs new holes.
              Bob Picard
                Spars?
                  Spars?
                  New front, old rear. L-2 wing rebuild.
                  Bob Picard
                    Get a hold of Aeronca/American Champion they have the correct nails for their wood spar decathalon's
