Fuel shutoff valve connection to cable
  • #31
    Mark - It is a finger strainer in the tank (on the 90 degree fitting)
    • #32
      • #33
        Thanks, just wanted to see you had one. It didn't look like the replacement ones you can get here in the states.
        Mark
        1945 BC12-D
        N39911, #6564
        • #34
          Originally posted by Bruce Caldwell View Post
          Ragwing nut, I sent a pm with my address. Thanks!!!
          I got it, and I'm digging one out
          • #35
            65hp was 3/8” npt male to 1/4” npt female, and the need to be drilled out all the way to the bottom, the brass fittings are only drilled part way, I also ream them to clear the screen for more flow at higher aoa, I use a ball end mill to get a good finish…
