C85 Conversion Complete!
  • #31
    To accompany Scott's welcome reference to Stromberg operation in #22 here's a similar brief on Marvel carburetors.
    http://www.kellyaerospace.com/articl...essory_AMT.pdf
    • #32
      Hey Tim,
      How are you cruising at 120mph with that climb prop?
      Only asking because I would love to make mine go faster.
      My F-19 cruises at about 90mph (gps) at 2450RPM with the cruise prop.
      Also, finally installed the fuel valves. Much better. Thanks!
      Get the longest and flattest propeller you can get, I ran a 7443 with a o-200, I started with a a 7446, I gained a lot of climb and it can cruise 105 kias with the last prop I had. I am not sure what my current one will do as a swapped from a Sensenich to a McCauley. The marvel carb is also great because of having a mixture.
      • #33
        RPM, I am running 2700-2750 and it was a sensenich, I have not tried the McCauley yet. The cruise prop would not turn RPM's, it dropped off at about 2600 with the 7446, the repitch made it a new airplane. The prewar airplanes are quite a bit faster for some reason which I believe is due to the angle of incidence, and mine has covered gear legs and a spinner which helps. Tim
        • #34
          What is your fuel GPH like cruising around at 2750? Is it a stock O-200?
          • #35
            6.5 gph or so
            • #36
              6.5 gph or so
              Okay. Any other downside to running around at redline all the time?
              • #37
                Kerbs
                That is one nice looking T-craft, I did the same conversion but added the starter after a near miss propping on ski's.
                i think it makes a great plane even better.
                Are those 8.5x6 tires?
                Did you happen to note the oil temperature delta to ambient?
                • #38
                  I never said I flew that way all the time, but the airplane is capable, I flew out of Delta Junction a lot for several years and never had any problems. I would fly to chicken; circle, central, tok , Palmer, fai, anc, Merril, all over and if the weather was good, it I would fly 10 hours on a Saturday because I enjoyed it. I did have a weird vibe at 2300 with the old prop so I either had to cruise at 2150 or 2450 because I did not have a spinner to do a dynamic balance at the time. I have yet to fly the new McCauley. I was able to get a new Sensenich if I want to go ack to that one. Tim
                  • #39
                    Originally posted by TC747paul View Post
                    Kerbs
                    Thanks, I appreciate it. The C85 makes it so much more fun, and it was a lot of fun to begin with. Yes, they are the Dresser 22" 8.50s. I really like them and they have held up well so far.
                    I did not make not of the oil temp to ambient. I have noticed that the oil temp is coming up a little higher than the 65 which I like, my 65 barely ever warmed up in the winter.
                    Stu
                    '46 BC12D
                    Jefferson County (0S9)
                    • #40
                      I am considering the same upgrade , but with a battery starter and no alternator.
                      what king of mags did you use and how was the fit. If you could send a picture that would be great. Where are you located at?
                      • #41
                        I went with Bendix mags. There are a number of pictures under the thread on carb ice continued that I posted recently or let me know if you want something else. I have a spreadsheet of everything that went on it along with the cost. PM me if you would like me to send it.
                        Stu
                        '46 BC12D
                        • #42
                          We have a Pitts S1S at my airfield that used to have battery starter, no alternator (or generator) for weight reduction.
                          It makes sense...you have the advantage of battery start, without the complexity & weight of alternators, voltage regulators etc.
                          Just one impulse mag, any brand, makes the whole process easier.
                          Plus, an S1S is easy to hand-swing if the battery gets cold, or flat.
                          • #43
                            Dual impulse slicks.
