Wing Inspection Hole questions
  • Wing Inspection Hole questions
    I saved the old fabric from my wing for locating inspection holes when installing the new fabric - which I'm doing now. My main question is this: what are they for? Just inspection? I see that they're located at the ends of each of the compression tubes. Are they to adjust the drag/anti-drag wire tension if necessary later? To tighten the bolts attaching the compression tubes to the spars later if necessary? (If so, it seems like there would need to be a hole on each side of the spar, or at least have the hole centered on the spars so you could get to both sides of the bolt).
    Brian Cantrell
    1946 Taylorcraft BC-12D, N96262
    1961 N35 Bonanza, N61GM
    Can't answer the what but here's a diagram of the suggested hole locations.
      From AC 43.13-1B
      2-14. INSPECTION RINGS AND DRAIN GROMMETS.
      a. Inspection Rings. Inspection access is provided adjacent to or over
      every control bellcrank, drag-wire junction, cable guide, pulley, wing
      fitting, or any other component throughout the aircraft which will be
      inspected or serviced annually. They are installed only on the bottom
      side of the wings except where installed on the top surface by the
      original manufacturer.
      Sully
      Sully
        They are for inspection for broken compression tubes, and loose or broken drag/antidrug wires. I know of a fellow finding one on a Waco once.
          My diagram! Mind you, the OP has quite rightly saved his old fabric for this very purpose. Cbcfly, is there any major difference?
          The reasons are exactly as 3Dreaming suggests. I have had to re-tension drag/antidrag wires in the past (not on a Taylorcraft); the majority of the holes (which should never need opening) are for that purpose. The rest (which do need opening) are for regular lubrication / inspection / maintenance.
          Hope that helps everyone.
            I haven't measured exactly, but yes, Robert, my original layout pretty much matches your handy drawing. Thanks for the input fellas.
            Brian Cantrell
              The FAA wants to see them opened up for the second annual after a recover, we are supposed to inspect the compression members and drag/anti drag wires. First annual you don't open them because the recover is fresh, its the second one we are supposed to inspect inside the wings. Tim
                Would they accept a bore scope if you didn't want to cut them out? ;-)
                  I tried that on a metal wing Ercoupe, when the AD came out for inspecting the spar, the PMI said "NO", I may have a borescope, but the next mechanic that inspects it may not have one, so he said - just follow the AD
                    You will want to carefully measure where they need to be installed above and below the aileron bell crank so you have them in the proper spot for lubing all the points there. A little bit off and it can make the task harder. Measure on the wing hardware unless you are sure the old fabric is right and verify off Rob's drawing.
                    Might consider one out on the wing tip if you have nav lights or are going to put in Sky Beacon's for ADSB.
                    Mark
                    Mark
                    1945 BC12-D
                    N39911, #6564
                      Complying with the requirements of an AD is a little different than every day inspections.
                        Do you have a 14' long borescope? That is pretty ridiculous to not cut them out for no practical purpose.
                          I never did get why they don't ever want to put them on or cut them out! It's pretty basic.....if you can't see it, how do you inspect it?
