Looking for Cessna 150 toe brake field approval
  • Looking for Cessna 150 toe brake field approval
    Hello Everyone,
    I have a local FAA inspector that is willing to help me with a field approval for installing 150 toe brakes in my BC12D.
    Does anyone have a field approval that I can get a copy of? This would help greatly! I would also need photos.
    Thank you,
    Jon
    Hi Jon,
    Why would you want to?
      I sent you pics of mine via email...and it is an excellent modification. Click image for larger version
Name:	brake pedal1.jpg
ID:	180811Click image for larger version
Name:	brake adapter2.jpg
ID:	180812Click image for larger version
Name:	brake adapter4.jpg
ID:	180813Click image for larger version
ID:	180814Click image for larger version
Name:	brake pedal2.jpg
ID:	180815Click image for larger version
ID:	180816Click image for larger version
Name:	brake adapter3.jpg
ID:	180817Click image for larger version
Name:	brake pedal3.jpg
ID:	180818Click image for larger version
ID:	180819Click image for larger version
Name:	installed wheel.jpg
ID:	180820Click image for larger version
Name:	final install.jpg
ID:	180824 One here scroll down: http://dc65stc.blogspot.com/2015/10/...fications.html
          I have one that I got from the foundation back when you could still get things from them. It's about 20 pages long including the front of the 337. I could email it to you if you give me an address.
            Please email paperwork to [email protected] This will help a lot!!!!
            Thank you.
            Jon
              Hi Jon,
              Because that's what I like. I have always liked the feel of the Cessna toe brakes.
                Don't "feel" them too hard! They look like they would be a LOT better than the cable brakes that were original. You might be able to accidentally do an outside loop landing and put her on her back (or at least blow out the tires when you stop the wheels and slide)! Your new brakes look solid enough to easily overcome the elevator on landing roll out and put you on your nose.
                I like them, but would use them VERY lightly! Then again, mine barely hold for a run up. ;-)
                  Our F-21 had Cleveland's and factory toe brakes. Loved it, and got me out of some trouble a couple times. Like everything you have to respect the airplane and know its limits.
                    The sensitivity of the toe brakes may be adjustable. Adding a spring over the master cylinder plunger would increase resistance (see Tim's pics above). Altering the toe piece to cylinder plunger geometry may do something similar. I'd make sure when landing there was no potential pre-loading when the rudder portion of the pedals were pressed. Setting the upper pedal angle versus toe position can correct for that somewhat in my experience.
                      JOHN, send me a copy and I will post it to the forum, or get me the Nnumber and I will order the CD. Tim
                        Tim, what's your email....it'll be on its way.
                          Jon, you should have about 21 emails. Let me know if it looks ok.
                              Ok...on their way to you Tim. Hope they all get there alright. I've got a bunch of stuff that I found that I'd gotten back when you could still get stuff from the foundation. I'll try to get it scanned and sent to you.
