an update is going in tonight. the forum might be on and off the air a couple times while this work is being done.
forum software update
Tags: None
Okay. It was a pretty rough upgrade from the very old version we were on to 5.4 of the forum software.
It didn't even let me use the old image files, just move the raw data from within the database. So, until Robert Lees or tcraft can look at the settings for appearance/logos/etc, this will have to do.
But i think i was able to get all the functionality back in place under https. the 5.x version of the forum seems a lot friendlier towards having https. Tho putting it under the secure (https) interface really buggered up the usually easy upgrade.
Anyhow, please check things out and confirm that everything is working.
For New Posts, try using this link (it works for me):
Hope this helps! (my comments in Red)
vb latest post.JPGAttached FilesLast edited by Robert Lees; 11-05-2018, 15:04.
To post a reply, you now have to "write something". See picture. It's so facebay
- Likes 1
Wow, this is different. I just sent a message to Admin, please disregard. Apparently I was signed-out during the changeover and that is why I could not post anything as this box does not show up until you sign back in. Thanks for the help and tips.
Are we going to have to somehow memorize that link you provided Rob to go to Unread Posts? That is not user friendly.Cheers,
Thanks Rob, good tips. One thing I wanted to do also was to "mark all forums read" (or something similar to that) so I didn't have to wade through all the topics again. I think I found it...
Select the Forums tab, then scroll down to the bottom of the list and select "Mark Channels Read". That seemed to reset everything so I'm only seeing new posts or replies (edit) after then selecting the "New Topics" tab.
VB Forum2.jpgLast edited by M Jones; 11-05-2018, 18:43.Mike
NC29624
1940 BC65
- Likes 1
Hank, look at the style selection at the bottom left of the screen, there are a lot of different combinations - i picked blue yellow as the default. you can pick something else - maybe one of them is more visable. How about grunge>
[email protected]
Works great. Got rid of the post rejection/double post issue too.
Awesome:yahoo: job
Thank youScott
Marty, try the New Topics at the beginning of the second line.Originally posted by M Towsley View PostWow, this is different. I just sent a message to Admin, please disregard. Apparently I was signed-out during the changeover and that is why I could not post anything as this box does not show up until you sign back in. Thanks for the help and tips.
Mike Wood
Montgomery, TX
'46 BC12D
N44085 #9885
I did, it does, works now! Thanks for the suggestion. I understand that we can't design the whole forum to compensate for me alone. I have a whole set of color filters that sometimes work GREAT when put in front of the screen. Now I don't need the filters for the forum! ;-)Originally posted by tcraft View PostHank, look at the style selection at the bottom left of the screen, there are a lot of different combinations - i picked blue yellow as the default. you can pick something else - maybe one of them is more visable. How about grunge>
Still need to figure out which one lets me see the VASI.
