Wash in wash in wash out how do those wires route?
  • Wash in wash in wash out how do those wires route?
    Hi All,
    I find the drag and anti-drag wire routing issue to be an interesting one.
    I think that I state correctly that the angle of attack at the wing tips aught to be lower than that of the wing root so that the root stalls first and the wing tips stall afterwards resulting in a more stable stall.
    More stable meaning that the nose tends to drop while there remains a bit of wing tip lift on each wing thus reducing the amount of roll that takes place.
    I assume that I am correct so far, advise as needed please.
    The change in angle of attack(AA) from a greater angle at the root to a lesser angle at the tip is called wash out? I get that that term confused it does not have a physical meaning that I can get glued to my brain.
    But the physical result is that the rear spar has to be a bit higher at the tip than at the root.
    I did some searching, not much, and find that 2 degree AA reduction at the tip is considered reasonable.
    These old planes have a front and rear spar that are separated by about 30" and the length of the spars is about 15' (approx.).
    Assuming that the 2 degree AA change is true and that the spars are in the same geometric plane at the root then the rear spar must raise up at the tip by about 1-1/16" ** more than the root to form that 2 degree angle.
    **1.05"=30" x sin(2 degrees)
    The amount that the rear spar raises up is linear. That is it raises smoothly along it's lenght and if you think about it in terms of how much it raises per inch of run along the rear spar it is; 1.05"/(15feet x 12"/foot)= .006"/inch
    The last bay's drag wire will be 1.05" higher at the rear spare than the at the front possible causing the wire push up against the anti-drag wire if the drag wire happens to be below the anti-drag wire.
    However the amount of possible inference between wires is not the full 1.05" but rather only a portion of that determined by how far apart they contact the rear spar.
    The bay's anti-drag wire connects to the rear spar at a point further inboard of the drag wire and that point on the rear spar is also raised with respect to the front spar but not by as much as the point where the drag wire contacts the rear spar. The difference those two heights is what can cause the possible interference.
    To find out how much that difference in height is for any drag/anit-drag wire set find the distance between the points of contact (in inches) at the rear spar and multiply by .006"/inch (see above). The long bay at a T-craft wing outboard end is about 60".
    So the diff in heights of the wires at the rear spar 60" x .006"/inch = .36". However if the wires interfere they do so half way between the front and rear spar resulting in half that interference or .18".
    I have an uncovered wing on the wing table so I put a digital protractor on the most inboard compression strut and set the protractor to reference that angle. I moved the protractor to the outermost compression strut, unbolted one spar at the lift strut fitting then twisted the wing to get a -2 degree reading as well as +2 degree. reading.
    I couldn't see any significant change in the wires look or feel. But I put a small piece of rubber hose on my wires then tape the hose in place so that the hoses are in contact and firmly taped together at the cross point.
    The wing on my table is a Champ wing and it's biggest bay is about 40" so it gets a lesser interference.
    It is the smart thing to do to put the drag wire on top so that interference is zero. However given the anti chafe used and the slight amount of interference I am not sure it really makes enough difference undo a lot of stuff to change it if you have it "wrong".
    Anyhow check out my math and reasoning. Does it makes sense to you?
    Re: Wash in wash in wash out how do those wires route?
    The wash degrees have been reported here as ~1.5*+-, and in a NASA report as ~3.5*. See pp. 22,35, and 39: https://ntrs.nasa.gov/archive/nasa/c...9930082385.pdf
    So 2* would be a reasonable ballpark value. Obviously the ultimate choice of washout and effect on internal wing components is up to the builder or later maintenance.
      Love it Dave. You can spot an engineer from a mile away. ;-) Your math looks fine to me (didn't run the numbers, just the logic) and I agree. It is probably NOT a huge difference, but I thought I remembered some drawing saying the drag wires went OVER the anti-drag and were supposed to be taped together. I like the tube over the wire better to make sure there is no chaffing. Refrigerator ice maker tube would work well and could then be taped together.
      Washout is specified here somewhere (by measuring height of the spars, not angles, but then the regular mechanics and pilots here don't usually use degrees like engineers, they measure distances at a wing station. It is actually much more accurate in the field.
        Dave, the way I remember washout is by lowering the tip angle, the air tends to "wash outboard" instead of straight back. Make any sense?
          I use a similar one. The stall washes out to the tip. If it washes IN to the fuselage you have no roll control in the stall.....unless of course you have a plane with the ailerons inboard. ;-)
          Remember to rig the wings "tips up".
            Remember to rig the wing trailing edges "tips up".
              Thread drift?...https://ntrs.nasa.gov/archive/nasa/c...9930083935.pdf observe the change in spanwise flow at the tips as the wing is progressively washed out = rear spar with more dihedral than the front. Seems to flow more directly front to back with increasing wash out. Perhaps due to changes in surface pressure differential above the wing, or whatever, like bottom to top surface spillage around the wing tips?
                Another stability benefit of wash out is that the ailerons continue to provide some roll control as the wing stalls. We're all trained not to use ailerons during a stall however training is one thing, reality is another. Especially in the case of a power-on stall and/or higher speed stall, having roll control deeper into the stall gives us a bit more time to recognize what's happening.
                A wing with no wash out will have a tendency to snap. I flew a citabria that had had the top of the wings rejuvenated a couple of times perhaps. The ongoing shrinkage of the dope caused a "wash-in" condition. Stalling the aircraft almost always resulted in a snap to the inverted! We recovered it.
                  Per the manual, the last full outboard rib is L.E. 1-5/16" up at the spar. the tip stalls first. Therefore when you fly it under the most common flight profile (number of souls on board, average fuel, any baggage and survival gear, etc), you adjust the aft struts so the airplane flies level. The flying wires need to be so that the inboard front wire (X) goes outboard needs to be under the inboard aft wire as they go outboard and forward
                    Huh? Trailing edge up. The root stalls first. Right?
                    A properly rigged tcraft flys happily, with roll control, at under 40 mph with the wing inboard stalled and the wing outboard, including the ailerons, not stalled. This is the result of the wash-out ie lower angle of incidence at the tip compared to the root
                      This gets confusing REALLY EASILY! I have seen a PhD in aero engineering get it screwed up. The wing tip needs to be at a LOWER angle of attack than the root. The aft spar should be UP from the front at the tip when the spar bottoms are level at the root. Leading edge at the tip DOWN compared to the root. DON'T GET IT BACKWARDS!!!!!!! I am TOO OLD to be a paul bearer. Some of us have put on a lot of weight.
                      REMEMBER WITH THE FUSELAGE LEVEL THE ROOT IS EVEN HIGHER AT THE LEADING EDGE THAN THE DRAWING BELOW SHOWS! The tip trailing edge at the tip is UP from the root!
                        CAPS LOCK button a bit too sticky, Hank?
                        Don't get het up about it; the washout diagram (in your post above) is in the Taylorcraft manual and it is up to the Owner, his Mechanic and his AI to follow that.
                        p.s. It's "Pallbearer" (< and relax >, that's my CDO done for today)
                          Too bad Taylorcraft didn't offer a similar dimensional figure for the wing root rib so an expected difference could be determined...for example 1 5/16" vs *** inboard? My wings are flat so I can't offer one.
                          Gary (-35F here)
                            Actually the caps lock is ALWAYS getting stuck on. ;-) I just wish I could find the data from when I set up my wings. I actually checked the washout at EACH (there it goes again) rib on both sides, mainly because I am an anal, OCD, overly curious engineer. What I found was that it changed a little at each rib and when rigged at the required wing span point it was different the rest of the way across. What was funny was that my plane flew hands off and doesn't even have a rudder tab. Even with the slightly "wavy" wing the average twist was really close when integrated across the span. It also has the same or less angle of attack outboard and more inboard, just like it should at every station, just not a nice linear progression. Before anyone gets worried about it I was using way more accuracy than they built the plane to, but I am pretty anal. You really do not need to check each station. I just sure wish I could find the spread sheet so I could tell you what the incidence angle was at the root and tip. Don't sweat in between (unless you are an engineer and can't help yourself).
                              Hi Rob,
                              Actually in some cases it is both.
                              Dave R
