Big tanks for the wings, something like a cub would have...18 gallons per side or there abouts? I am acquiring some piper tanks to see how the fit in the wings between the ribs...just something I am pondering. Tim
So what do you think about BIG wing tanks?
Re: So what do you think about...????
Depends on what engine you are running? I have the 2 wing tanks on a 65 and has more endurance than I have, did 5 hours once. There was a 337 on the website for 2 six gallon tanks per side? The wires runing threw the tank would be something, will thay line up?Andrew Rozell
N43697
1946 BC12-D
Well since 6 gallon wing tanks are fairly scarce, I was thinking of doing the 18 gallon per side plus the 12 gallon header....Tim
I like the idea of flying into somewhere and back without getting fuel....N29787
Originally posted by astjp2 View PostWell since 6 gallon wing tanks are fairly scarce, I was thinking of doing the 18 gallon per side plus the 12 gallon header....Tim
I like the idea of flying into somewhere and back without getting fuel....Marvin Post TF 519
I brought 27599 back to WI from Alamosa, CO. in three non-stop 5hr legs, with all (3) tanks full at each days start. Five hours non-stop in nice Wx is enough for me. The five in mild turbulence on day three was misery.MIKE CUSHWAY
1938 BF50 NC20407
1940 BC NC27599
TF#733
Originally posted by astjp2 View PostBig tanks for the wings,
Said owner subsequently sent me photos of the installation. Lordy knows where those photos are now, but I'll have a look. This was a Canadian machine, so probably on their "Owner Maintenance" programme (similar to our UK "Permit to Fly" system).
Tim, remind me in a few days. Dementia will set in otherwise.
OK, I found the original TOC Newsletter entry, but I don't know where my colour photos are.
This newsletter entry is from June 1997 (so not quite the 20 years ago I was thinking). It applies to a TG-6 conversion to an L-2A as is apparent in the text.
Legal bit: Copyright notwithstanding, this is posted in good faith (I was a paid up member of the TOC back then).
Sensible bit: Do any of our Canadian Tribe know what became of this aircraft?
The fine print looks like 10 gallon tanks. Aircraft is in the States, now: N68577, LOWE ROBERT E
BOX 16, JACKSONVILLE, OR 97530
Oops, take that back. It was deregistered in 1973 so that means it went to Canada then. Sorry.Last edited by M Towsley; 04-24-2014, 12:48.Cheers,
Originally posted by M Towsley View PostThe fine print looks like 10 gallon tanks. Aircraft is in the States, now: N68577, LOWE ROBERT E
Originally posted by astjp2 View PostBig tanks for the wings, something like a cub would have...18 gallons per side or there abouts? I am acquiring some piper tanks to see how the fit in the wings between the ribs...just something I am pondering. Tim
It requires a SERIOUS redesign, but Chuck and I have been looking at using the inner two bays of the wings for a tank that uses the top and bottom skins of the tank as the wing skins (no fabric over it, only a tape around the edges). It would require a tank that could carry the shear loads and would be a major design mod but would allow us to get the 12Gal tank out of the nose over our knees and would free up all the space in front of the panel. CG of the tank would be so close to the aircraft CG that fuel use wouldn't change CG in flight. The other thing that's nice is it is EASY to see any leaks and check the tanks. Taking them in and out would be a snap. Problem is it is a pretty big mod from the paper side.
Hank, I'm servicing a Pa-22-160 taildragger at the moment. It has reasonably big tanks in the wings (appx 18 USG per side) with a hard skin on the top surface only, but of course with brace wires through the tank.
Would it not be simpler (paperwork - wise) to do similar, rather than have stressed skins above & below?
Robert P : The Pa22 (and I'm sure others in the fabric high-wing Piper series) do not have the middle dummy rib that caused problems to you and so many others. Not one of the finest features of the Taylorcraft designs.
