Re: Rear window frames
I need to get them from the file (file sounds like pile which is what all my drawings are in on the guest bed) and take them down to the engineering copy center to make a copy. I have two types of wood frame drawings. One is the factory type that are made from thin strips wrapped around a form you cut from MDF. I made a set for my 41 but built them up like the tail surfaces on the old Guillows rubber models. It makes the wood wider so the screws have more "meat" to go in. Since I was making the wood wider I could use lower strength Poplar wood instead of spruce strips and still be much stronger for a gain of less than a pound of weight. I have both drawings and can send them for the cost of copies and postage, usually less than $10 each.
Send me your address at hjarrett2 at cox dot net and I will pull them out and copy the ones you want.
ops:
