Re: Unshielded ignition ends
I've used a hand held radio to sniff out ignition static. Sometimes it's easier to connect a portable antenna with a long piece of coax to make the sensing flexible in tight spots. Remove the antenna to lower the sensitivity if needed. On one engine it was due to a poor engine-frame ground that allowed the control cables and tach to carry the noise into the cockpit. If common mode current on cables or wires are suspect static can sometimes be suppressed with ferrite beads or cores placed on the wires. There's also firewall mounted feed-through filter capacitors available. The cowling should be electrically bonded to the frame.
But sparks are sparks and I wonder if resistor plugs or wires are available? (Edit: for the older non-shielded spark plugs only...shielded plugs typically contain resistors)
