I can't seem to find exact replacements for these pulleys. Anyone know where I can find them or a pulley with which I can legally replace them? Thanx, Larry
An228 & AN229
Re: An228 & AN229
This pulled up off the forum via the "search" feature:
TAYLORCRAFT PULLEY • $23 • ACCEPTING ORDERS • FAA-PMA 9/30, Ball Bearing style replacement pulley fits Taylorcraft A-228 3.0" and A-229 1.75" • Contact Donna Losey & Doug Combs - CLASSIC AERO located Gilbert, AZ USA • Telephone: 480-650-0883 • Fax: 484-762-6711 • Posted March 9, 2009 • Show all Ads posted by this Advertiser • Recommend This Ad to a Friend • Email Advertiser • Save to Watchlist • Report This Ad • View Larger Pictures
__________________
Ron Greene
TF#360Dick Smith N5207M TF#159
Re: An228 & AN229
Larry: I have some well used original pulleys that I could send you, but enen though I'm a stickler for making everything original I don't recommend that you use them. The ball bearing pulleys are much superior to the originals. At least, try replacing a few of the 3" pulleys in your aileron circuit...the difference is amazing.Bob Gustafson
NC43913
TF#565
Re: An228 & AN229
I, too, just bought new pulleys from Doug Combs. But the groove (where the cable goes) is not cut as deep as in my existing bushed pulley. So now, I cannot get the new pulley in place unless I make the cable longer by turning the turnbuckle in the tail. My AI doesn't want to do this if he doesn't have to. Any suggestions?Last edited by TimHicks; 12-28-2009, 06:47.Tim Hicks
N96872
Re: An228 & AN229
Originally posted by TimHicks View PostI, too, just bought new pulleys from Doug Combs. But the groove (where the cable goes) is not cut as deep as in my existing bushed pulley. So now, I cannot get the new pulley in place unless I make the cable longer by turning the turnbuckle in the tail. My AI doesn't want to do this if he doesn't have to. Any suggestions?
It just shows you how worn the old ones were. Lengthen out the turnbuckles and re-safety. While you are doing the turnbuckles it would be a good time to check the bolts where the cable attaches to the elevator. Tom
Re: An228 & AN229
I don't think that the old pulley groove is worn. I'm replacing them because of the nicks in the flange (see my earlier picture). But see the sketch below. The middle pulley is what the new pulleys look like. The one on the right is what my old one looks like. The imaginary one on the left is what I imagine the new one would look like if the groove were worn to the diameter of the old one. But the old one doesn't look like that at all. The groove is tapered, not straight-walledLast edited by TimHicks; 12-28-2009, 08:59.Tim Hicks
N96872
Re: An228 & AN229
I'm really surprised that others haven't had this problem. I just assumed that the pulleys that I had were original to the airplane. Now I'm doubting that.
I'm convinced that the deeper grooves are machined that way. It is not wear causing the depth. The cables go into and out of the pulley without fighting the pulley. In fact, look at the pictures attached. You can see paint on the insides of the groove from overspray from the last time the airplane was painted (decades ago). If the cables were touching the flanges, the paint wouldn't have stayed there long.
The diameter (at the bottom of the groove) in the old pulley is about 2.515"
The groove diameter of the new pulley is about 2.690"Tim Hicks
N96872
Re: An228 & AN229
I think you are right. That overspray would have stripped off the first few passes of the cable if it was touching. I wonder if someone turned the pulley on a lathe with a little round jewelers file or some sandpaper to clean it up sometime in the past. You can even put a pulley on a nut and bolt and use a drill press for that (NO, I am NOT recommending it, I have just seen it done!).
You haven't been scared till a small jewelers file zips past your head and sticks in the wall from some knucklehead using a drill press and saw or file for a lathe! I expected to get shot at in the military, but NOT with a file!
