F22 wings
    More likely behind the throttle plate (it looks more post-war than pre-war)
      Can you take a pic of the engine mount?
        No, F-19 has toe brake as well
        Those cast pedals are not bc, they would have been a cable pull, not a push caliper...
          Originally posted by TC747paul View Post
          it is listed experimental, so it looks like i am the proud owner of a bit of a mutt. the seller called it a F22 so i went with it. i like it all the same. It did come with a 0235 mount. The big thing is get the wings done and fitted,. i will check on the serial number on the hinge areas. is there a specific location that is more apt to have the number?
          thanks again, you have all shown a keen eye and knowledge of the Taylorcraft
          thanks
          Paul
          Dynafocal mount? Can I possibly borrow to copy or buy?
Name:	0235 mount two.jpg
ID:	184403Click image for larger version
Name:	0235 mount one.jpg
            sorry i was gone all week and back home now
            here are some pictures of the mount
            it came with shims, i am thinking for angling the engine off center line???
            i could make a 3d cadd or 2d set of drawings if you like
            thanks gain all
            Paul
              thanks gain all
              Paul
              I would love to build a jig from your mount if you would rent it to me.
                That's not a dynafocal mount. Dynafocal mount all the bolts point to a central point. they are not parallel.
                  I would take anything I can get that would fit a lycoming...I have access to a 150 hp that would make one hell of a homebuilt....
