I am FINALLY ready to hang the wings back on my 41 BC-12-65 and was getting everything lined up and ready when I took a close look at the attach fittings on the fuselage. Typical of many of our older birds in areas that are covered a lot and don't get much cosmetic attention, the drilled ears had a LOT of layers of old paint and the bolts (which I had just put back in the holes without much thought to keep from loosing them when I took the wings off) were really covered with multiple layers of paint. Since I didn't want to use elastic stop nuts again and had new castellated nuts for cotter pins I took the old bolts and threw them in a jar of solvent (solvent REALLY messes up elastic nuts!). Then took my mighty #11 X-acto knife and scraped off about 10 layers of paint from the fuselage lug. When I did this (without breaking the ancient original primer I might add) a layer of paint IN THE HOLE also came out. When I took the now clean bolts back to the fuselage the rear spar bolts had enough clearance to "rattle" in the holes! The slop was being taken up by all the paint (they were tight before).
Now for the question (bet you guys thought I would NEVER get here). I KNOW lots of other planes must have had worn spar to fuselage holes. Should I;
1) Sleeve the hole and go back with the original bolts
2) Clean up the holes and go with 1 step oversize
3) Ream and go to the next size up bolt (anybody know what size was original? What is the max bolt size?)
4) Lay a weld bead in the hole and re-drill
5) Peen the lug so it is tight on the bolt again (No, I am NOT doing that, but have seen it done. Made my hair stand on end!)
What has been done in the past and how was it documented to the FAA?
