All,
I know you all won't believe it but I finally found the drawings of the 41 and 45 "D" window frames. :yahoo: I have messages from Dale Jewett, R.M. Pearson and Mike Jones as asking for copies.
The post war ones are the stamped sheet metal frames with the smaller windows. The late ones are much bigger and more rectangular. I DO NOT have those. I am pretty sure there was an intermediate sized frame too which I also never had.
The pre war "D" windows were very close in size and shape to the early post war ones, only with wood frames. The pre war drawings I made are of the frames I reverse engineered for my 41 and the "hole" is the same size and shape but the wood is softer, lighter easier to fabricate and has more area to support the glass. The strength is actually higher than the original (now that I have finally seen how Taylorcraft actually did it) because there is more wood. The original frames appear to have been laminated from thin strip and the screws that hold the outer frame and plexi need to be VERY accurately placed to hit the laminated wood. I think one reason so many of the original frames are not around any more is the thin wood rots out. My replacement frames are wider and should last the life of the aircraft. When I replaced my frames there was a pile of rotten wood behind the headliner with the window held in by the screws through the fabric.
If someone has a laminated 41 frame I can borrow I will do drawings of it for those who want originality. I "think" if you use modern sealing materials on one and CAREFULLY align the parts it could be made to work. When I recover I would like to try it. But then I'm nuts enough to want to go for total originality. If it doesn't work I will reuse my frames.
Bottom line, If Dale, Richard, Mike (or any others) want a copy of the drawings please drop me an email at hjarrett2 at cox dot net with your mailing address and which one you want. The copy cost was $2 for the 1945 frame drawing and $1 for the 41 plus postage (engineering and drafting is free).
P.S.
Yes, I know I already have some of your mailing addresses, but do you REALLY want to wait till I dig those out too?
P.S.
