It has come to my attention that the martin clips from Aircraft Spruce are not the right size, I wish I had know that as we threw our originals away and made no effort to save them thinking the new ones would fit, can anyone help with this problem? I have heard of some folks that my have enough of the original martin clips for sale. Any help would be appriciated.
Martin clips
Re: Martin clips
I was glad when I recovered my wing that I did save Most of them,the friend that was helping me take the cover off wasn't as carefull,I had to replace a couple ribs worth.but my IA had some extra from previous jobs.If you cant find any,ill see if he has some more.
PV
Re: Martin clips
Ok, are the Martin clips different than the Taylorcraft wires or was it a fabrication problem. See “Wire Clips” thread and others that come up when doing a search for “martin clips”.
It appears that it may be possible to get the correct clips from someone like Aircraftspruce assuming the fabricating machine is working properly.
BlakeBlake Carlson
Crookston, MN
1941 BC12-65
N47665
Member #1009
Re: Martin clips
Regular Martin Clip spacing is 3" while Taylorcraft Martin Clips are 3-1/8" spacing.
I was lucky & got enough Clips to do my plane with the project.
AirCraft Spruces lists reg Martin Clips & also Taylorcraft Martin clips, I would asume they are diff. Different part numbers anyway. I suppose you could phone them & ask spacing on Taylor ones? Or you could simply order a single roll & see how they fit? Surely someone must have purchased some from them lately!46 BC-12D Taylorcraft
46 Chief
Re: Martin clips
Well I have not measured the hole spacing but I guess I'll order the taylor craft ones and hope for the best. Man I wish I had known this. Oh well such is life when doing a project such as this.Live for today for we know not what tomorrow holds
Re: Martin clips
Originally posted by Ray View PostWell I have not measured the hole spacing but I guess I'll order the taylor craft ones and hope for the best. Man I wish I had known this. Oh well such is life when doing a project such as this.
My wings were in almost perfect, as in brand new shape, holes were not enlarged or marked up. The jig however that makes the holes in the ribs at factory must have been out of spec as one row of holes on both wings was out enough to be a PITA. I ended up straightening the 90* & rebending it. One row on both wings was spaced at about 3-1/4"
I wish I could tell you where my Martins came from but I see in Spruce one roll covers 25' I recieved two rolls with my project & one roll did the both wings but for two ribs. Sorry other roll is not for sale, another Taylor project being started this winter.46 BC-12D Taylorcraft
46 Chief
Re: Martin clips
Has anyone used the Cessna clips in place of Martin wire , and is that legal if it fits, The Martin wire sold by Aircraft Spruce is 31/8 inch spacing, and does not line up with the holes in Taylorcraft stamped ribs,also they have only one type of wire available, it would require a Z bend as previously disscussed, Has any one have any old Taylorcraft wire or know of a good option?
