Gap?
  • Gap?
    Attached is a picture of the alerion push-rod attachment hardware. I just drilled my holes and for grins attached the hardware. There is a gap of about 1/16" between the two pieces of hardware (as shown). Is a gap OK and if not, can I simply put an appropriately holed washer in the gap? - MikeH
    Re: Gap?
    Hi Mike, sorry to say that I don't get it. Where is the gap? Dave
      Re: Gap?
      Between the push rod bracket (the vertical piece on the left) and the hardware that supports it (the horizontal piece on the top); the line points to where I now have a 1/16" gap - MikeH
        Re: Gap?
        hmm
        Mine does not have that horizintal piece on the top
          Re: Gap?
          Are you saying the bolt head is not pulling down tight against the surface of the bracket?
          Winston Larison
          1006 Sealy st.
          Galveston TX, 77550
            Re: Gap?
            Let me take a pic of the new install; it will probably be clearer - MikeH
              Re: Gap?
              There should not be a gap between the two and the bracket does not look square to the spar either. Have you pulled the plates to check for cracks?
                Re: Gap?
                That's a poor pic of the original install. I'll get a pic of the new install and post it tonight.
                If a 1/16" gap did appear, could I use an appropriately thick washer to close the gap? - MikeH
                  Re: Gap?
                  OK - first attachment shows the general view. Second attachment zooms in on the gap I'm asking about - Mike
                    Re: Gap?
                    Just bolt it together, it will suck up tight when its together. Tim
                      Re: Gap?
                      No, that will put the bolts in a bind and side load the hole which could propagate a crack. Install an appropiate shim of the correct thickness. The threads on the stud should be long enough to handle the length
                        Re: Gap?
                        By 'stud' you mean the bolt on the push rod, correct?
                        And the correct thickness washer will make an excellent shim - MikeH
                          Re: Gap?
                          Correct, the ball stud.
                            Re: Gap?
                            I am certainly no expert here, but a close inspection of the picture showing the bracket shows the right side of the vertical bracket to be slightly deformed. Would removing the bracket and straightening the right side help close the gap?
                              Re: Gap?
                              Hard to tell whether straightening it would decrease or increase the gap, either way it seems like a good thing to do first.
                              DC
