Attached is a picture of the alerion push-rod attachment hardware. I just drilled my holes and for grins attached the hardware. There is a gap of about 1/16" between the two pieces of hardware (as shown). Is a gap OK and if not, can I simply put an appropriately holed washer in the gap? - MikeH
Gap?
Re: Gap?
Originally posted by drude View PostHi Mike, sorry to say that I don't get it. Where is the gap? DaveMike Horowitz
Re: Gap?
Originally posted by mhorowit View PostBetween the push rod bracket (the vertical piece on the left) and the hardware that supports it (the horizontal piece on the top); the line points to where I now have a 1/16" gap - MikeHWinston Larison
1006 Sealy st.
Galveston TX, 77550
Re: Gap?
Originally posted by Ragwing nut View PostThere should not be a gap between the two and the bracket does not look square to the spar either. Have you pulled the plates to check for cracks?
If a 1/16" gap did appear, could I use an appropriately thick washer to close the gap? - MikeHMike Horowitz
Re: Gap?
Originally posted by astjp2 View PostJust bolt it together, it will suck up tight when its together. Tim
Re: Gap?
Originally posted by Ragwing nut View PostNo, that will put the bolts in a bind and side load the hole which could propagate a crack. Install an appropiate shim of the correct thickness. The threads on the stud should be long enough to handle the length
And the correct thickness washer will make an excellent shim - MikeHMike Horowitz
Re: Gap?
I am certainly no expert here, but a close inspection of the picture showing the bracket shows the right side of the vertical bracket to be slightly deformed. Would removing the bracket and straightening the right side help close the gap?Richard Pearson
