Faux Fairleads
  • Faux Fairleads
    These look a lot like BC-12D fairleads. Same outside diameter as original with slightly more wall thickness. Genuine phenolic.
    Make then by chucking the phenolic tube on a dowel, spin it in a drill press while dragging a needle file on the tube. This process takes about 10 minutes per piece. If you don't have a big honking drill press then wrap masking tape around a reasonably large dowel until the dowel is built up enough to hold the tube. A little more tape holds the tube to the dowel on one end while you groove the other end.
    :joy:
    Taylorcraft needs ten of these. I will provide 12 pieces of tube, cut to length but not grooved for 10 bucks and I'll pay shipping in the CONUS. You can screw up two of them learning to cut the grooves yourself -- really you don't want to pay 2 hours of A&P shop rates for someone to cut the grooves now do you?
    This is my "get rich quick" product. If everyone in the tribe buys a set I can retire before I turn 96.
    Best Regards,
    Re: Faux Fairleads
    you have found a spot. If everyone that could ,make a small piece there wouldn't be all of the confusion. good work.
      Re: Faux Fairleads
      Howdy Mark! (I received your private e-mail - Thanks) I'll order two sets and let you retire at age 95 - Hey...whatever helps. Merry Christmas to all.
      Doc
      Doc TF #680
      Assend Dragon Aviation
      FAA Senior AME #20969
      EAA TC #5453 / FA #1905
      CAF Life Member #2782
      "Leben ohne Reue"
        Re: Faux Fairleads
        I would like to order a set where do I send the money
          Re: Faux Fairleads
          Mark:
          I could use a set of those fairleads, too. It's great to see folks making these hard-to-find parts. If we all produced a part or two we could manufacture that T-Craft kit ourselves!
          Hey, here's an idea. If this fairlead gig doesn't fully fund your retirement...just don't retire. Refuse to leave. Tell the bastards you want to die at work. Make them deal with your dead, stinking carcass.
          Just kidding, Mark. Don't do that. If the fairlead gig doesn't work out you can just retire into poverty. Like the rest of us.
          Bob Gustafson
          Bob Gustafson
          NC43913
          TF#565
            Re: Faux Fairleads
            Bob,
            Thanks for the chuckle.
            Send a private message with your address and I'll drop a set in the mail to you. Pay later if you like them.
            I have two other cutomers so far so my profit is up to 39 cents
            Best Regards,
              Re: Faux Fairleads
              Mark,
              I would like a set also. Please send to. Buell Powell. P.O. Box 571, San Marcos, TX 78667. Hope you put all the profit for something worthwhile like gas for the T/craft.
              Buell
              Buell Powell TF#476
              1941 BC12-65 NC29748
              1946 Fairchild 24 NC81330
                Re: Faux Fairleads
                Howdy: 12/24/2006 Just an update for the 10 fairleads found hanging on my hangar door handle at 1T8...it was a mighty nice looking Christmas wreath Mark! Anyway, I put a micrometer on the new leads...they were just a little larger than the originals and they would not safely be tapped into the rings. I took a one-handled hack saw blade and slightly deepened the grooves, and then lightly belt sanded the tubes until I could get an individual snug fit on the rings. If your leads come without grooves, I would suggest you dry fit them before grooving for the snap rings. They look original and are better than the stock tubes! Let's call them ersatz (replacement) leads rather than faux (fake) leads! Doc
                Doc TF #680
                "Leben ohne Reue"
                  Re: Faux Fairleads
                  Seems to me you were provided "Material" and manufactured the fairleads as an "Owner Manufactured Part". Right?
                    Re: Faux Fairleads
                    Well...that is what my work log entry says! Doc
                    Doc TF #680
                    "Leben ohne Reue"
                      Re: Faux Fairleads
                      I got my 12 Julicher fairleads last week and put them on my "T" this morning. Beautiful! A bit more work than the nylon fairleads, but worth it. Original style and phenolic too.
                      I fabricated some primitive tooling (photos here, click on "Fairleads, Phenolic") to make finishing them a bit faster. If anyone would like to use my "tooling" to make their own fairleads drop me a note on the PM and I'll send it along.
                      Bob Gustafson
                      Bob Gustafson
                      NC43913
                      TF#565
