Thank you all. Now to source or make the bushings. The outside was definitely metal to metal. Not good. Tge inside two(The double hold downs for both tubes definitely take a larger thickness shim or two ganged.
Sure am glad I took this apart for painting. So sending off all the cables to McFarlane (sp).
New pulkys going back on (needle bearing type) by the way all the pulls and hold downs of the rudder bars and H bar were put on with bolts using aircraft grade stop nuts...no drilled bolts . Is that acceptable?
