Removable Rudder Pedals
  • Removable Rudder Pedals
    Here's one I hadn't seen before........... anyone ever run into "Removable Right Rudder Pedals" I have a set of rudder pedal bars that have the right side just bolted on, as if maybe there might be times when they don't want the right side to have rudder controls.......... I also have a couple of extra "bolt on" rudder pedals..... what gives with this?
    Did the company offer such a thing, that bolts on, or removes at the pilot's discretion.........
    I am finding some new things every day.......
    Jon Click image for larger version
Name:	Removable Right Rudder Pedals.JPG
    "Captain Jon" Timlin
    My BC12D has them removable on the right side too.
      So maybe that was an option.........
        Both of my planes have bolt on RH pedals as well as a number of spare sets in the parts pile.
          Yes, you can remove them and install pedals that have toe brakes...just say'n
            Ah! Now there's a thought! But you'd then have to fly it from the right seat.............. I have not seen any left pedal as "bolt ons"..........
            OK, you brought it up............ how tough will it be to convert my Model 19 project from mechanical drum Clevelands (it came with straight axels) to heel (or toe) hydraulics, or maybe just mechanical disc brakes..........?
              Piper style pull masters mounted on the gear legs, run the cables from the heel brakes to them, install disc brakes on axles, mount the reservoirs on the masters. Pretty easy to be honest.
                Maybe this way also.
                  Does anyone have a 337 for something like that?
                    I'd like to see the completed installation.................... will there be a bellcrank of some sort to transfer the cable pull force to the brake cylinders?
                      pull masters, no bellcrank required
                        Terry Bowden DER
                        https://dc65stc.blogspot.com/2018/06...ke-kit-on.html
                        Sully
                        Sully
                          Thanks, Sully. That's the first I have seen of Terry's diagrams of the systems. I think he must have updated the site since I last visited. That's a lot for brakes that get seldom used, and almost twice what Tami T-Craft cost back in 1976 when I bought her. I assume that price is for tapered axle planes, so maybe a little less for my Model 19 with straight axles...... still, nearly $12K for both............ hmmmm Maybe those old Shinns and Clevelands aren't that bad after all.........
                          I know I am already going to have much more into these projects than their market value when they are done, but adding another $6K each......... I need to talk to Terry........
                            ...Maybe those old Shinns...<snip>
                            Those old Shinn drum brakes may not be up to modern standards, but they suit lightweight aircraft like ours.
                              REALLY TRUE! Our planes are in more danger from strong brakes than weak ones. Planes on their backs are a great source for restoration projects. I DON'T WANT more brakes than needed for a run up/mag check. It is all about energy management.
