Originally posted by Hank Jarrett
View Post
Gap seal
Do you have VG's?Originally posted by KewFlyer View PostTribe.
I have been using Gap Seals in the elevators and rudder for years, not only on the Taylorcraft but on the SuperCub and Cub. The added control at low air speeds and responsiveness to small inputs while in flight, are priceless. Regarding legality, all logs books have been dully signed at annual by the IA. Caviate: the gap seals are surgical tape and NOT a permanent fixture to the airframe. Regarding ailerons gap seals, I use a 4" tape that attaches 1" to the wing with the remaining 3" covered with the same tape under it, just floating over the aileron. Im very happy with the improvements and added controls.
I have been asked: "do you notice the difference?". I have on the elevator authority and rudder and not as much in the ailerons...but..thats just me.N29787
I can wrap a prewar up in a spin like crazy, and recover easily...but my airplane rigging is stock.Originally posted by PA1195 View PostHanks testing would be valuable. I've used the seals from Post #10 for three years on my elevators. Goals were various: exclude ice and snow while parked and removable to clean if covered; not glued just inserted; better elevator and trim control feel but that's only subjective; better control of AOA in and out of the stall and while landing 3-pt. I have VG's so the underside of the rear horizontal stabilizer has them for control authority so that alone may suffice. I didn't try w or w/o the VG's before the seals as they were there previously.
One early series of study by the NACA (three total by Fred Weick and others; I can link if interested) was an examination of roll, stability, control of stall, and other performance behavior like the degree of adverse aileron yaw. Their recommendation was for Taylorcraft to add increased vertical stabilizer and rudder area [which they did after WWII along with a revised aileron-wing cove like Stinson and Piper PA-12-14]. Spins were a problem at that time and flight divergence near the envelope edges was compared with variable control deflection. Altering approved control behavior and stall has consequences so caution is still recommended.
Bellanca sealed ailerons on Citabrias via an optional kit. I heard it improved aileron authority and rate of roll. I added then and it did as advertised. Same for elevator seals which later became a factory option. But in that case a tester likely wearing a chute approved the Utility Category maneuvers and others.
GaryN29787
Early Micro VG's lacked the under stabilizer VG's. I flew them on a PA-18A before and after. With them installed elevator control (without gap seals) was improved at low airspeed and particularly at forward CG or slow landing on floats. Installed the plane could be flown to 28 GPS, but when it stalled there was nothing left in the wing so as they say "The cows got bigger". It's a good mod if used responsibly just like gap seals.
- Likes 1
Do you have VG's Tim? With them spins are resisted but can be provoked. Rudder remains to prevent or delay that mode.Originally posted by astjp2 View Post
I used to do them before I got the VG's, and I have done them with. 11 rotations is my max. I have also been able to cross control the ailerons, opposite rudder, wings level and turn a 360 rotation. Windows would rattle a lot but the prewar airplane has a lot of rudder control, the post war I flew in would drop a wing.N29787
It's an engineer thing. First thing we tend to think about is "Why does it do that and how can I get some numbers to describe it and provide guidance to make it better?" From the time I bought my first T in the mid 70s I was always bothered by the lack of data on performance. For me, analysis isn't pain, it is fun, but then I read tech journals for recreation..Originally posted by astjp2 View Post
Hank, why would you even try to go through this process? If you like pain, go find a fence post that is 48" high and bang your head into it... it will hurt less than dealing with the faa
These and their bibliography cover lots of early testing of taylorcraft and airfoil:
What happened with the GeeBee was that the aileron stalled as it was deflected downward in a cross wind and in 3 point attitude, effectively reversing the controls. Luckily he is as quick as he is and he got it handled in time. He said that was the last time he ever tried to 3 point it.Originally posted by PA1195 View PostTaylorcraft flap hinge.jpg
I thought aileron reversal was when the aileron deflection was capable of twisting the rear of the wing up with down aileron, or down with a up aileron. Like at Wartime Airspeed with a weak wing structure? I doubt the Taylorcraft can go fast enough for that but structural twist at speed....wouldn't surprise me with matchstick spars.
I guess "aileron reversal" isn't an adequate description, but that's what he called it. Here's a page he wrote in a book about it.
I suspect that with the elliptical wing of the GB the tip wants to stall. If so down aileron may provoke it sooner especially if there's no washout to the wing for speed. See the pics>>>> 2H8Bm.jpgOriginally posted by N96337 View PostWhat happened with the GeeBee was that the aileron stalled as it was deflected downward in a cross wind and in 3 point attitude, effectively reversing the controls. Luckily he is as quick as he is and he got it handled in time. He said that was the last time he ever tried to 3 point it.
I guess "aileron reversal" isn't an adequate description, but that's what he called it. Here's a page he wrote in a book about itN36007 1941 BF12-65 STC'd as BC12D-4-85
- Likes 1
There was a naca test for pitching and flap design, usa35b @12% chord was acceptableOriginally posted by N96337 View PostTim, wasn't it you that said something about the 35B airfoil? I was wondering what the Tern did? It's been so long since I saw one I can't remember.
JohnN29787
- Likes 1
Hank, I think you missed my point, I would do you testing and just keep your mouth shut to the powers that be...and then report your results.Originally posted by Hank Jarrett View Post
HankN29787
- Likes 1
