Wing Rib
  • Wing Rib
    Due to a mistake on my part, I am in immediate need to a wing rib for my F21. It is the outer rib. The last one before the wing tip. Any help with a source would be appreciated.
    Jim
    Re: Wing Rib
    left or right flange looking from the back
      Re: Wing Rib
      Is it the same as the regular post war rib at the tip? I have some. Post a photo of the damaged one and I will check the parts pile for a match.
        Re: Wing Rib
        I have a set of uncovered BC12-D wings here. If they are correct and the same as a F21, then the flange goes to the tip. Left wing Left flange, Right wing Right flange.
          Re: Wing Rib
          I will double check but the damage is to the left wing so I believe it is left flange. The damage is behind the rear spar. Missed the aileron. How has on for sale.
          Jim
            Re: Wing Rib
            Make that who has one for sale?
            Jim
              Re: Wing Rib
              Need a photo (preferably with something for scale like a yard stick next to it). I have several but need to know which one.
                Re: Wing Rib
                It is the smaller full rib that closes out the aileron and tip bow attaches to
                  Re: Wing Rib
                  As viewed from the back (trailing edge), that is different to my BC12D. Port wing underside:
                    Re: Wing Rib
                    Yes Robert, that is the correct rib. The picture shows the right wing, flange right from the rear. I need the end rib for the left wing, flange left from the rear.
                    Jim
                      Re: Wing Rib
                      OK. Now that the rib is identified, I need to buy one right know. I can repair the damaged one but I would rather replace it. Who has one that they will sell me?
                      Jim
                        Re: Wing Rib
                        PM sent.
