Re: Martin wire
Tape over the lacing won't stop the lacing from rubbing the rib. The instructions need to say to put tape over the RIB, BEFORE the covering, so the tape covers the edge of the rib. If you are going to use the tape for anti chaff protection it also needs to be pushed around the sharp edge.
If the instructions just say to put tape over the stitches that doesn't fix the problem. As said before, I have never used stitching on a stamped rib so I haven't read those instructions. Can you post them for the rest of us?
