Re: Strut angle conundrum
I'm not metal savy but wonder if all it would take is a torch and bending to create the strut offset noted? That's a quick fix. But to build a second part number would seem extreme and imply that others would be needed to fix an as of yet unproduced variation in some wings. Are there two strut part numbers?
Edit: Did look at what info I had available and saw the same front lift strut P/N A-A815 for both earlier and F-19. However after 1/1/79 for F-19 S/N F-137 on a larger strut was available plus a different speed cuff to cover the outboard attach point, tiedown clamps, and jury strut clamps. New size listed is 3.48x1.187". Earlier was 2.360".
Sources: http://www.taylorcraft.org/docs/tayl...20list%20B.pdf and http://www.taylorcraft.org/docs/Tayl...anual_1985.pdf
