Adapter plate failed !!!
  • #61
    Re: Adapter plate failed !!!
    [QUOTE=astjp2;91576]I have 3, 2 at the shop and 1 in my spare parts pile at home...
    Do you want to sell any of these, and what condition??
    • #62
      Luscombe foundation makes new pma hubs.
      • #63
        Are you sure they are PMA parts Mike?
        I asked that to them a few years ago and came away thinking that they are not PMA.
        • #64
          Each part for the hub has this after it on the Classic Aero site: May or May Not have FAA approval Document.
          • #65
            LOL
            Thanks Marty, that cracks me up.
            I guess you have a 50-50 chance.
            p.s. wow $795 for new one and about a $100 less for a reconditioned one. One of my first engineering managers would often debate/discuss tech. issued with comrades in the hall and then say "well that may or may not be true" and invite into to his office for further discussion. That always cracked me up too. It may or may not be true - genius! , who woulda thought it could be so.
            • #66
              I'll link this in case Eddie the OP or mechanic Fred wants to contact them: http://shop.classicaero.info/searchq...ords=propeller
              • #67
                Gary,
                This goes to your concern about parts qualification from yesterday. I doubt these are PMA parts.
                p.s.- I did not find a PMA approval listed for Classic Aero or any for a prop hub that might have been the one on the site.
                • #68
                  Thanks Dave and Marty for the info on the quals...I guess one could ask before committing to a purchase regardless of the source, especially now that the FAA may have been invited into the fray.
                  Edit: Surely some facility or Repair Station (like Aircraft Specialties Serv.) can yea or nay a component. We've done that before but of course to engine parts with an OEM P/N. Much yet to learn regarding this.
                  I may ask Eddie and Fred for a look at the parts...not to wash any dirty laundry in public but rather to learn something worth knowing about the composite assembly. That adapter was completely separated around its circumference, appeared to an amateur's eye to have been previously corroded, and showed visible surface wear (I've looked at it up close). Any wear on the starter adapter or prop hub would be enlightening.
                  From what I know so far the only thing holding the prop to the plane was an interference fit between separated parts of the broken flange. I assume the hub of the prop slips over the adapter hub...and might as well slip off with the separated portion of the adapter still attached (???). Or does the nut and forward ring assembly retain the prop as well?
                  • #69
                    blue-
                    I think its fair to say that before the Luscombe group started making hubs that many mechanics could identify the Continental hubs and inspect them or get them inspected for defects.
                    The addition of the Luscombe hubs makes it a little more confusing because if I am correct and they are not PMA parts then we should not use them. One give away is that beautiful cad plate finish which the Luscombe hubs have an most TCM hubs don't unless they have been replated or it is a NOS TCM hub.
                    red-
                    Yes you are right on. Eddie was very fortunate. What if that prop and partial hub separated and hit the wing? tail? partially separated shook the engine off? or just can cleanly off an hit someone on the ground?
                    God has something planned for Eddie! Eddie escaped a tight spot.
                    • #70
                      Eddie speaks and acts as a Godly man, and for good reason now even more so I suspect. The cracks in the adapter must have been at the right angle to prevent component departure and retain rotation with the crankshaft.
                      Are there P/N or manufacturer ID's on the OEM hub components? I can see where knockoff dupes would be hard to ID without them. Buyer be advised.
                      • #71
                        Gary,
                        Do you think the old original Continental hubs are PMA'd?
                        • #72
                          I doubt PMA was in play then, was it? Were any of the old Continental parts PMA'd? I doubt it.
                          But I do believe they came from a qualified source. In this environment the common standard for qualified and legal purchased replacement parts is the PMA system.
                          What else should we go by?
                          • #73
                            I have one. I know where there are two more good (used) for sale at $300 plus shipping. If that is of interest send me a PM
                            Best Regards,
                            • #74
                              Probably not, from what I was told by a good source
                              • #75
                                I don't need new, I just need good serviceable for what I fly and that's what I have.... There are NOS ones at Fresno but you pay for them. This is not a Cessna...so not much for support, that is why we have to make due or make our own parts sometimes. Tim
