Re: Adapter plate failed !!!
Interesting Gary, thanks.
My conjecture has been that the points that you noted were nearly centered on the the lightening holes and that they were the start of the crack.
The corrosion that you noticed may reinforce my conjecture.
The reason that I take that path of thought is because I imagined the outer portion of the hub (where the bolts are) as the rim of a bike wheel.
Then I imagine the next portion inward toward the center (where the lightening holes are) as the portion of a bike wheel where the spokes are and the "spoke" as being the metal between the lightening holes.
So then I imagine that if the hole in the ring gear plate has a diameter that is large enough such that the edge of that hole contacts the hub at a point that is adjacent to or outboard of the innermost edge of lightening hole (where the crack "point" is) then maybe something odd happens.
Maybe the entire prop load is transferred to the hub center thru the "spokes" which are not as well braced as they would be when a prop alone was installed and the hub is acting more nearly like a rim of bolts connected to a center than a round plate.
If the suspected activity took place one might expect the flexing of the spokes to result in a crack starting at the most inboard point of the lightening hole.
Sorry for all the words, hope it is discernible, picture is worth a thousand words, I may have used that many!
Having seen little of it I was interested in your observation of the cracks.
No doubt there are other possibilities.
Thanks for the observations, Dave.
