Experimental Tcraft
  • Experimental Tcraft
    Does anyone know of an experimental Tcraft for sale. Preferably 150+HP, flaps, etc. but experimental registration first.
    Jim
    Re: Experimental Tcraft
    There's a white one on ebay.
    F22 Experimental Build
    46 BC12-D
    N95078
      I knew I had seen one recently but could not remember where. Here is the link for the Ebay T-Craft: http://www.ebay.com/itm/LSA-Taylorcr...m=301911339297
        It would be interesting to know what form of experimental certification it carries.
          If it is a factory prototype or pre-production prototype experimental be very careful that you can actually FLY it when you get it! If it never got a production type cert it could be a barrel of problems to actually USE it.
          Might not be a problem, but be sure BEFORE you buy her. This is NOT like Experimental as in home built!
            Hank, It doesn't appear to be a factory prototype or pre-production as it states in the first sentence of the description: 1946 Taylorcraft BC-12D rebuilt and converted to a Model 19.Re-certified as Experimental on 12/2009.
            Tom, it states on the registration it is a Thompson Craft, manufacturer: Thompson, Ryan L and it is an Experimental Amateur Built. Not sure if that helps you determine what it is.
              Experimental Amateur Built is the best experimental type to have. There are several different experimental sub types.
              I was thinking the FAA had an order in place at the time it says this airplane was converted that you could not change a type certified aircraft into an "Experimental Amateur Built". I know in talking with the local FSDO that even tough I had a letter from the FAA stating a Swick clipwing Taylorcraft met the 51% rule for a amateur built aircraft that it now couldn't be registered that way.
                That's a nice airplane....she's at the next aerofield down the way from me...about five miles. Looked her over a time or two, but never looked at the books. I'd heard it was experimental, assumed they'd done it under "exp. exhibition" but I guess not.
                Stumpy
                N43319
                BC12D
                  I can imagine that someone claimed that they built it from scratch...
