Desser 850 Smooth Tundra vs 600
  • Desser 850 Smooth Tundra vs 600
    850's came in the other day. Here they are next to a 600
    Re: Desser 850 Smooth Tundra vs 600
    How much do they weigh?
      Website says under 10 lbs. I'm glad they finally got TSO'd, I might be grabbing a pair soon.
      F22 Experimental Build
      46 BC12-D
      N95078
        Yeah, they feel like they weight about the same if not less than the 600's. The carcass as a whole is very soft/pliable/flexible compared to the 600 (especially the sidewall).
          Are they 22" tall?
            Where is the best place to order a pair of those and how much will they cost?
              Rich dresser is in memphis Tn can order direct from them.
                Justin,
                Have you mounted the 850's yet? When you do how's about a pic or two and a pirep? My 800's are nearing their end and these are lighter, and not that much bigger, relatively anyway.
                Thanks
                Stumpy
                N43319
                BC12D
                  Here is a link to dressers web site about this tire.
                  http://www.desser.com/store/products...H-TUNDRA-.html
                    $600 to save 10 lbs....not bad...Tim
                      I bet there are lots of people who would gladly pay $60 per pound to lower their empty weight, and I'm not just talking airplanes.
                        M-kay
                        Got them on
                        Couldn't believe they weight about the same as the stockers 11.6 Lbs tube and tire compared to 11.8 Lbs 850 tube/tire
                            Will post the 337 process as we go through it.
                              Just duplicate mine, its in the tech ref. section. Just leave out the ply rating part. Tim
