Desser 850 Smooth Tundra vs 600
  • #31
    Re: Desser 850 Smooth Tundra vs 600
    I remove the valve core, stick one of those little criss cross tools inside the stem with a nut hanging from it, pull the tube stem through the wheel and then install the nut...
    • #32
      I recently installed the 29” airstreaks and I’m having a lot of fun with them. So far I have landed on ice,snow, tar and some soft fields. The visibility isn’t all that great while taxiing but it isn’t a whole lot worse than the 800s I had on before. They do grab very good on asphalt if your not careful and I found that wheel landing or 3pt then raising the tail on rollout helps a lot with visibility and cushion. My cruise speed went from 115 to about 110 mph ias
