A65-9
  • A65-9
    According to the Continental Engine service manual for A65, A75 and A80 the -9 model has a mount in the case for a starter with it are a different mag gear (only one) starter gear and different oil screen set up. Has any one any experience with this and would a new small style starter fit in cowl for a Standard Taylorcraft? Are the parts hard to find ?
    Re: A65-9
    If memory serves me right the 1955 Mooney Mite (M18C-55) came with a starter . If there is a Mooney Mite forum they may be able to help you with your inquiry about that engine. Why do I know something like this? I used to own a Mite. For those who know me, can you believe that I was able to fit in one of those little things once? It was a great little fun airplane to play pretend fighter pilot in.
    Bob Picard
    N48923 L-2B Skis/Wheels
    Anchor Point, Alaska TF#254
      Re: A65-9
      see barnstormer ad below that I saw a few days ago
      A65-9 ACCESSORY • $400 • CLEANING OUT THE HANGAR • A65-9 accessory case 400.00 obo • Contact William J. Musselman - FAIR WEATHER FLYERS located Prosser, WA USA • Telephone: 509-338-5222 . • Posted November 23, 2014
      also the fellow that posted this ad (Thomas Wottreng) may have info and parts
      CONTINENTAL A65 90SMOH • $4,000 • ACCEPTING OFFERS • New Slick mags. Strombeg carb. Good running engine install on an experimental. Includes propeller • Contact Thomas C. Wottreng, Friend of Owner - located Elkhorn, WI USA • Telephone: 262-203-0799 • Posted November 28, 2014
        Re: A65-9
        -9 uses a bunch of -9 only bastard parts that are hard to find. The starter is impossible to find because its is made like a baby radial engine starter. They are about the same depth as a -12 so I suggest that route with a mini starter.
          Re: A65-9
          I have a complete case and accessory case I can part with...Tim
            Re: A65-9
            Thanks for all your replies , Just finding out what is available.
              Re: A65-9
              I have a -9 accessory case that I'd sell for a lot less than the guy wants on barnstormers.
              N27432
                Re: A65-9
                Details?
                What all do I need?
                Price?
                  Re: A65-9
                  The -9 engines wern't used in many aircraft. The big downfall is the HUGE starter used. It's the AN style and weighs a ton. No light-weight starters are made to fit this application. All of the gears in back are specific to the -9. I would take Mike's advise and look for an A65-12. They are pretty tough to find also, but when found alot less headache.
                  EO
                    Re: A65-9
                    The -9 engine would probably fit on a long mount they are hard to find then you have to change the top and bottom cowls to answer your question a b&c starter will fit on a short mount using a dash 12 engine they come in the 75/85/90 horse power range the dash 9 was continentals bastard step child if you need a starter go with a dash 12 engine.
                      Re: A65-9
                      I have been reading that the A65-12 used the same accessory case as the C75 do you know if you could build a A65-12 from parts from a C75 ?, and what kind of difficulty with legality, that would be ?
                        Re: A65-9
                        Hi Chuck,
                        Can you remove the starter after the engine is installed?
                        Did you use a key switch or a button?
                        I am thinking of a button instead of a key switch.
                        Wicks has these on sale now for $565 is that a good price?
                        Thanks, Dave
                          Re: A65-9
                          The A65-12 uses the same crankcase and rear case as the C series. The difference is in the diameter of the bore registers. The A series uses a smaller bore so the skirt portion is smaller, the crankcase is machined to this smaller diameter.
                          Continental considers only the engine series and not the dash number. In the front of the Service Manual they devote a paragraph to this. The dash numbers just indicates the modification level of the engine. The -8 has no provision for starter/generator and the -12 with starter/generator INSTALLED. Remove the starter/generator and install factory cover plates and you have a -12 with PROVISION for starter/generator, but not installed. So, if you need the starter/generator you have one option the -12. If you don't need these items you have 2 choices.
                          Regulatory issue would be, if the A65 is required it has to be an A65 regardless of dash number. If you install a C series engine it would require some kind of supplemental approval.
                          EO
                            Re: A65-9
                            Number one there is no such engine the A65-12 does not exist period.No A series engine other then the dash 9 had the option to put on a starter.Now the dash 8 engines of the C series also did not have a place for a starter either.The dash 12 and dash14 and 0200 had a pad for the starter,also there was no engine in the C series that was rated at 65 horse power.Drude i used a push button you have to drop the engine off the top mounts to get the starter off now the only one that will fit is a B&C so if that is what wicks is selling that is a good price my starter cost me $795.00
                              Re: A65-9
                              Perhaps you should check the A-65 T.C.data sheet, It adresses the -2 model
