If I remember correctly the exhaust on an A65 exits the cowling on the co-pilots side of a taylorcraft. If you see a 46 Taylorcraft BC12-D A65 with what looks like the exhaust coming out of the pilots side what does that mean? Some type of aftermarket homemade flamboozal stuff?
Exhaust
Re: Exhaust
I'm in the middle of my annual right now. After going through the painful removal of my heat muff I was blessed with a hole in my exhaust. After experiencing what everybody else had talked about, I called Terry for the paperwork and then Doug at the Luscombe foundation. I bought everything through the foundation and even had Doug mount the baffles and muffs for me. It seemed like a lot money, but since my exhaust and muff where toast anyway, it really wasn't much difference to upgrade.Dave
F22 Experimental Build
46 BC12-D
N95078
Re: Exhaust
No! No...NO..No.no.nooooooooooooooooooooooooooooooo!
The 4-into-1 Taylorcraft exhaust is a lovely sound; how could you roughneck ne'er do wells ruin it by sticking dual stacks on? It'll sound like one of those American tractor trucks.
My stainless 4-1 has lasted 2500 hours now, and not a whisper of a crack.
Re: Exhaust
No four cylinder is going to sound like a 409.
Chris, if it was back in the old days I would say they reversed the negative. Lol.
Rob, I agree with you. I like my 4-into-1 and the way it sounds.Cheers,
Re: Exhaust
Originally posted by Chris View PostNow Im really curious. I may have to call the guy. I'd be more interested if it wasn't in Massachusetts and winter!
Re: Exhaust
The luscombe exhaust not only sounds different and good it also makes more heat for the cabin and carb. The easy access to the accessory case. At annual time the inspection of them is a snap and if your cowl is for a lycoming 65 it has the holes all ready in it and the pipes exit in the existing holes.1940 BLT/BC65 N26658 SER#2000
