Bucket List and Prop Removal
  • Bucket List and Prop Removal
    Just cleared one more item from my bucket list, spent the last two weeks in OKC and passed the writtens and O&P's for the A&P certificate. Wow, was that ever intense.
    Has anyone seen or made a U-Tube video on the removal of a prop from a tapered shaft Continental A-65 engine?
    David Johnson
    Wichita, Kansas
    TF#958
    BC12-D
    Re: Bucket List and Prop Removal
    When they are stuck, you don't document things like that!
    On a non-joking response, if you are about to do something you wouldn't want on film to take a prop off you are doing something wrong!
      Removal of the prop from the prop hub is easier with the tapered crank than with the flanged crank....just undo the prop nuts. I always use nyloc nuts on the prop bolts on a tapered crank (awaiting comment ).
      However, removal of a prop from the flanged crank requires cutting the wirelocking of the heads of the bolts (and re-wire-locking upon prop installation).
      Do you mean removal of the hub from the crank? This requires a few tools and a large torque wrench to put it all back together.
      (please excuse the corrosion on the tool...I don't use it that often).
      There are a few other tools for hub removal, of which I don't have photos yet. It's a good idea to remove the hub periodically to check for corrosion / cracks, especially in the keyway slot.
      Hope this helps.
        David and Robert,
        I have an article with illustrations on how to make the tools you need and remove and re-install the prop and hub if that will help.
        Buell Powell TF#476
        1941 BC12-65 NC29748
        1946 Fairchild 24 NC81330
          Buell,
          If you are willing to give the article freely, then I can add it to the Taylorcraft Foundation Technical Resources.
          If so, PM me for my email address.
          Thanks.
            Hope this helps.
            Hi Rob,
            I would never apply that much torque to that hub nut.
            I have seen hubs cracked right down that keyway and its a waste of a good hub and I attribute it solely to over torqing.
            My suggestion is to follow the attached service letter from Aeronca. Fundamentally I do that except that I thoroughly coat the taper and the inside of the hub with antisieze compound (moly) as opposed to light oil.
            Been doing it that way since 1987 and swapping between two props each on their own hub and no problems taking off ot installing.
            One time I did get one stuck but applying heat to the hub after removing the prop popped it off that may have been in 1998 when i experimented momentarily with bees wax.
            p.s. even if the Cont. manual gives that torque I would not use it.
            oops! the pdf file will not upload, its only 1M
            this works=> http://www.aeronca.com/docs/HelpsAnd...1-Feb-1961.pdf
            we had this debate before
              Robert, yes, I meant removal of the hub from the crank. I miss-typed my question.
              David Johnson
              Wichita, Kansas
              TF#958
              BC12-D
                Drude, when I click on the aeronca link it shows as not available.
                  thanks,
                  try now I think that I fixed it
                    Here you go. While searching for this on my computer I also found a document from the FAA that shows the approved props for popular engines like the C85, C90, & O200, if anyone needs it.
