Old. BIG TACH. Everything works! All original, plus non sensetive Altimeter and the proper A/s indicator All can be mounted in an original panel. I can also make a copy of the original formed panel overlay, but its gonna cost ya! Also have running A-40 w/prop. Another fresh looking A40 I got from Forrest ( who knows what its insides are like) My A model is currently wearing a low time A-65 with a fresh boot and open cowling., Lots of pre war wing stuff. Someone that knows what it is needs to get this stuff before I die. 405-808-6683
ORIGINAL Big round tach with oil press.and temp.
I left a phone# for a reason. I DON'T TEXT. If anyone wants to contact me , my phone# is 405-808-6683. My Email is [email protected]. I will not text message
Ok, for all you looking for pictures of the assembly of a big tach with oil temp and oil pressure. Here you go. Word of caution here; I do not recommend attempt disassembly. Pictures provided for entertainment value only. The meter connections to the bourdon tubes are very delicate as well as the tach spring-shaft assembly. High Risk of permanent damage and loss of calibration! Removal of the glass from front cover very risky. Note the staked points in the front cover. Probably a find another good cover kind of repair if yours is damaged.
I purchased this assembly knowing it needed attention when I got it. Guarantee of serviceability not provided.Attached Files- IMG_4008.jpg (133.5 KB, 175 views)
Brent N27662 SN2304 BC65
You can get a replacement bezel from the antique clock community. When I did my BL I silkscreened the face and the two small plates for the oil temp and pressure. I left the tach and oil pressure alone, but sent the oil temp out for repair.
