Painted to look like cowl trim
    Re: Painted to look like cowl trim
    No rocks to be thrown.
    Taste is,....well, a matter of taste!
    Hank ;-)
      Hank, I'm headed to surgery in the am I will try to get some and post when I can.
        Originally posted by TimHicks View Post
        I'm thinking about painting my '46 BC12D with a "Deluxe" paint job like in the pic below.
        I'm not interested in actually acquiring the cowl trim.
        But I'm curious if anybody has ever tried painting the lines on the cowl so that from 30 feet away, it looks like it has cowl trim.
        What do y'all think? Feasible?
        If the pic is accurate, i am fairly certain the odd "D" windows I have for a prewar are actually these for a early postwar deluxe!
          Ragwing,
          Just to be clear, the picture in my first post is from an old TCraft ad. It is not a picture of my '46.
          I don't know the vintage of the airplane in the ad.
          In this thread, Hank indicated that the trim was available in '41. And Louie's '41 has the front part of the trim. So that seems to confirm what Hank said.
          So maybe we can assume that the ship in the ad is a '41.
          I may have used the word "Deluxe" erroneously in my first post. I've seen this paint scheme called "Deluxe" in the past (on this forum). I didn't mean to imply anything about my model or the model of the airplane in the ad.
          Tim
          Tim Hicks
          N96872
            Airplane pictured is a BC12D Deluxe built right after ( or even during the end) of the war and used for the magazine shots. It may have been assembled from prewar partsf or a "mixed bag" airplane sort of like Hanks 45, which is why it retains some pre war characteristics
            Ryan Newell
            1946 BC12D NC43754
            1953 15A N23JW
            TF#897
              Ryan,
              I bet you are right. If you look close there are a few pieces missing from the trim. They stop it on the cowl instead of running it all the way back to the door handle. They probably didn't have full sets of the trim still available. It looks like it does have a "blown" windshield like the post war planes and I'm not sure which door it has. Looks like a big compass. A plane built from parts right after the war makes sense. The NC number is not active, but it is between my 41 and 45.
                There wer postwar Deluxes, I have the remains of one, but not complete. The d window in the pic is not the same as a prewar deluxe d window. The one I have fits standard prewar tube doors. I will have to dig them out and post a pic.
                  My 41 has the side trim and no D windows. I now have the grill pieces almost ready for return to the nose bowl. Although my grills are post war repoductions they fit my nose bowl, some bowls will not fit the wrap around grill wings.
                  L
                    I found the repo grills very thin and easily to bend so I filled the back of them with exopy and tooth picks to reinforce the exopy. This made them very stiff and strong. After 5 years they are still good and the exopy has stayed in the grills.
                    Dennis McGuire
                      I was talking about my cast grills being repo's. I have a set of the thin stamped aluminum ones too. I spent one evening straighting them with most of my effort in shrinking the web where stretched. I don't plan on using them as I have a set of cast grills close to ready for mounting.
                      L
                        I tried to simulate the cowl trim by cutting strips of aluminum tape.
                        After carefully applying the tape and taking these three photos, I decided that I didn't like the look, and immediately removed the tapes.
                        It doesn't seem to add anything to my airplane.
                        I think that I will abandon the idea of painting on these stripes and just be content with the existing paint scheme.
                        Tim Hicks
                        N96872
                          Your right Tim. Maybe paint a pretty girl on there like some of the WW2 military planes. LOL
                          Marvin Post TF 519
                          • #28
                            How does one find out if their aircraft was delivered from the factory as an Ace, Standard or Deluxe model.
                            Would Forrest have that information?
                            David Johnson
                            Wichita, Kansas
                            TF#958
                            BC12-D
                            • #29
                              Start with the FAA info CD. Look for things like "no LH door" for clues. See if anything was added in later paperwork to "upgrade".
                              Believe it or not, I have a 1940 B that was upgraded to a BC-12D-85 at one time. They went as far as to change the empennage to 2-hinges on the rudder and elevators! Darn shame.
                              MIKE CUSHWAY
                              1938 BF50 NC20407
                              1940 BC NC27599
                              TF#733
