Hot starts
  • Hot starts
    Does anyone have recommendations for hot engine starting A75 with stromberg carb?
    Re: Hot starts
    Don't prime it pull it threw 4or 5 blades and listen for a sucking noise from the air intake make the mags hot and it shoud start
      Re: Hot starts
      65 or 75 or 85 with Stromberg will start hot with no prime or pull-through, but requires a little more throttle than a cold start.
      I use 1 inch of throttle with someone competent in the seat (and on the brakes) and with chocks, or I swing from behind the prop with my left hand in the cabin to bring the throttle back to idle immediately upon start. The engine will run up quick.
      The trick is the 1" of throttle and NO PRIME and NO pulling through.
        Re: Hot starts
        On our O-200, it is a pain to hot start and what I find out works very well is to just turn off the mags at idle. When it is time to restart, I don't touch anything except to make the mags hot and it usually starts on one or two blades. (normal shutdown is with the mixture)
          Re: Hot starts
          Continentals instructions for shutdown is to allow the engine to idle then turn off the mags. As the engine is running down, briskly advance the throttle until it is full open. I am assuming this keeps the engine from pulling fuel into the carb while at idle setting, causing a rich/primed hot start. Remember, you can prime the engine at idle while pulling the prop through, the same thing happens while your engine is winding down after mag shut off.
          Don't forget to move the throttle back to idle before you exit the plane or your next start is guaranteed to be exciting.
            Re: Hot starts
            What mags do you have? Do they have impulse couplings?
              Re: Hot starts
              it would be best to get at the root of the problem and make sure you don't have weak coils in the mag or excessive spark plug gap.
                Re: Hot starts
                Ours starts hot by the third pull everytime no matter the temp. We do not have impulse. Had sometrouble around the fourth of July hot starting (Cold starting was fine). Right Mag went bad during run up few days later. Changed out the mag and have had no issues since in close to 100 degree temps. We hot start ours similar to what Chuck suggested. Being the first year run in many years we had to find "What worked" and that procedure seemed to be it. (A65, SF4 Mags, Strom Carb)
                Ryan Newell
                1946 BC12D NC43754
                1953 15A N23JW
                TF#897
                  Re: Hot starts
                  My A65 starts hot EVERY time if shutdown exactly as Marty says. At idle, cut the mags and advance the throttle full open. Restart is with no prime, just go hot with the mags and throttle set 1/8" out.
                  MIKE CUSHWAY
                  1938 BF50 NC20407
                  1940 BC NC27599
                  TF#733
                    Re: Hot starts
                    Scintilla mags are known to have a "hotter" spark (stronger coil) it also matters whether you have impulse coupling.
                      Re: Hot starts
                      Ive tryied that a couple times but it starts better just by turning the mags on with a little throttle and starts good
                        Re: Hot starts
                        You rarely see two small Continentals that work exactly the same. If you take the engine out of service and store it, the procedures will change. If you top it or do a major, the procedures seem to change. I don't know what it is, but once you find the right little "tweaks" for YOUR engine for starting in warm and cold weather and with the engine cold or still warm, you will have it pretty well covered. It will stay the same for years and seem to work every time.
                        You can NOT rely on how the guy in the other hangar starts his plane, no matter HOW well it works on his. Just keep trying what you can till you "break the code" for your engine. Once you do, it will start in one flip almost every time.
                        Always worth it when someone with another 65 engine watches you and says "it'll NEVER start that way!" and yours fires up on the first flip.
                          Re: Hot starts
                          Hank,
                          I always pretty much use the same precedure for every A65/75 with a stromburg carb and have never had any major issues....occasionally a little cranky hot starting if I forget to turn off the gas while its setting or somthing, and sometimes cold weather starts take a few start & quits before they want to idle but that's to be expected without preheat. I always cold start the same way, I always shut down the same way for hot starts which is a little different then what I do if I'm shutting down for the day.
                            Re: Hot starts
                            Well, this is my " engine code":
                            Hot or cold start:
                            With the mags off, 1/8" ( plus minus) throttle open, one full blade backwards, mags hot, and a good pull usually does the trick.
                            [ you can hear a hisss sound of the cylinders getting charged..... or it could be my imagination ]
                            Shut down: I let the engine idle for say 1 minute, while I get things ready and organized to exit the plane, then run on one mag for a few seconds...say 10 to 15, and then to off. I don't touch the main fuel valve; stays open at all times.
                            Stromberg carb and CASE mags (not for long !!!).
                            Hope this helps
                            Ralph
