Re: throttlle cable routing
If the temp's not too hot I use spiral wrap available at auto or electronics stores. Also use split fuel hose over the line or cable. It can be split with scissors in a radial fashion or simply in a straight cut. Nylon ties also have base mounts that self stick or can be fastened with hardware to surfaces and the tie loops through them.
