Ok guys and gals, here is my problem.
I drained all the fuel out of my L2 to refurbish the fuel valve. I put five to six gallons of fuel back into the right tank and it shows about half full. Since this is a six gallon tank that feeds directly into the header tank I assume that two gallons went there. Two days later, the right tank still shows half full and the left tank still shows empty. The two tanks are interconnected via a common fuel drain in the center at the bottom of the fuselage, they both feed the header tank and, in addition, both of the main tanks and the header tank are vented to each other. The fuel caps are also vented.
The airplane is on a level surface, shouldn't the tank quantities have equalized? Why is the left tank still empty?
