Anyone know of a company doing NDT testing in Houston area to comply with AD 2008-04-09?
Wing Strut Testing in Houston
Re: Wing Strut Testing in Houston
Strut testing is running $200 - $300 not including the installation/removal/treatment, etc.Originally posted by avenger1949 View PostI can have struts tested for what.... 40 years for the cost of new struts...? Or am I confused.
So from an economical standpoint, yes, testing is likely a better value but increased hassle. Not sure why the value would reduce $5K if you don't have sealed ones as they could be installed for much less than that. Guess it depends on what the buyer wants. From a safety standpoint I don't think there is an advantage either way.
Originally posted by fearofpavement View PostStrut testing is running $200 - $300 not including the installation/removal/treatment, etc.
You have to test the struts every 4 years for land planes?Dale
T.F.# 1086
If one of them fails you don't have to buy new struts. You only have to replace the one that failed. It can be replaced with a used strut that passes the inspection.Originally posted by astjp2 View PostYes and if one of them fails, you are still required to buy new struts. Tim
Take shit off, put shit back on. :sleeping:
Originally posted by avenger1949 View PostThat was what happened in my case, one was real bad, one had a few spots, one had one spot the tester didn't like... one was like new... found a guy who had some the took off and bought the ones I needed... all was goodN29787
Had the ones I put on tested... they were like new inside.... sorry you have had such a bad time but sounds from your posts like you come by it honest. Good struts are good struts... and I won't live long enough to make up the difference. Also taking you struts off once every 4 years let you inspect the fittings which as we all know do wear out. So in my case better to be safe then cause yet another dumb AD1946 BC12-D N44178
Wichita Ks
