Wing Strut Testing in Houston
  • Wing Strut Testing in Houston
    Anyone know of a company doing NDT testing in Houston area to comply with AD 2008-04-09?
    Mike Wood
    Montgomery, TX
    '46 BC12D
    N44085 #9885
    Re: Wing Strut Testing in Houston
    Buy new struts, no more AD.
      I can have struts tested for what.... 40 years for the cost of new struts...? Or am I confused.
      1946 BC12-D N44178
      Wichita Ks
        and it can take 5,000 off the value of your airplane. seen it done!
          Strut testing is running $200 - $300 not including the installation/removal/treatment, etc.
          So from an economical standpoint, yes, testing is likely a better value but increased hassle. Not sure why the value would reduce $5K if you don't have sealed ones as they could be installed for much less than that. Guess it depends on what the buyer wants. From a safety standpoint I don't think there is an advantage either way.
            You have to test the struts every 4 years for land planes?
            Dale
            T.F.# 1086
              Yes and if one of them fails, you are still required to buy new struts. Tim
                If one of them fails you don't have to buy new struts. You only have to replace the one that failed. It can be replaced with a used strut that passes the inspection.
                  That was what happened in my case, one was real bad, one had a few spots, one had one spot the tester didn't like... one was like new... found a guy who had some the took off and bought the ones I needed... all was good
                  1946 BC12-D N44178
                  Wichita Ks
                    Take shit off, put shit back on.
                      Had the ones I put on tested... they were like new inside.... sorry you have had such a bad time but sounds from your posts like you come by it honest. Good struts are good struts... and I won't live long enough to make up the difference. Also taking you struts off once every 4 years let you inspect the fittings which as we all know do wear out. So in my case better to be safe then cause yet another dumb AD
                      1946 BC12-D N44178
                      Wichita Ks
