Re: Soft Cylinder
For the time it takes to monkey with the valve, just pull it and do it right! You can give a better examination of the cylinder and fix what else is wrong. I have 2 spare cores if you want to just swap it. They are .015. You can also clean up the crud on the piston and pin and poke your head inside the case to check the cam lobes. Tim
