Well had a bad day. My 1946 BC12D with a Cont 65hp and alum prop taxied into a Citabria. The prop sliced through the wing of the Citabria and hit the spar right at the wing strut fitting. The prop is bent on both ends and a chunk of alum about the size of a dime is missing where that blade hit the metal strut wing fitting.
What do I do now? Does the engine have to be torn down? Has a flange hub. I was not there when it occurred so I don't know what RPM it was running at the time and did not check if the prop would turn etc.
Thank God no one hurt, just my buddy's pride and wallet.
