Is there a scientific procedure for determining prop selection and if not scientific is there an acceptable run of thumb
for a given length you have some factor of efficiency you would think this could be mapped for a given rpm range and is dependent on torque
for a given prop pitch you have a level of efficiency tide to this as well as given torque.
this would leave us to believe that a finer pitched long prop would be the same as a coarse pitched short prop
the peak torque of a motor is the most efficient rpm or best mpg do we then prop for a given MP at cruise for this rpm for the best cruise prop
but then how do we decide the best climb prop. we could do the efficiency if it was linear for a range of lengths against the pitch number X rpm to get a volume of air moved?
so after the food for thought has been digested please educate me.
