Windshield Vents
  • Windshield Vents
    More heat issues!
    Anybody have a link to a photo of an old ship with the vents in the upper area of the windshield?
    Thoughts as to whether the Vistavent Spruce sells would be appropriate?
    Josh
    Last edited by bashibazouk; 07-02-2011, 10:39. Reason: Added picture of vent and additional question.
    Bashibazouk AKA Josh Brehm
    BL-65 #1705
    TF #910
    NC47~ South Oaks Aerodrome
    EAA 1423
    Winterville, NC
    Re: Windshield Vents
    Josh,
    I put the Vistavents in the door windows in my 41 and they work very well-really nice to have-especially here in South Texas.
    Buell Powell TF#476
    1941 BC12-65 NC29748
    1946 Fairchild 24 NC81330
      Josh,
      I have those in my current plane, it came that way. The restorers did not put opening windows in, bummer. Anyway, I installed the other type of vents that snap-in on my L-2 in the upper windshield area. Those worked very well. The vents you are showing, I think, flow less than the snap-ins that rotate. Just my thoughts on it...
        Thanks Buell and Marty.
        Marty, were the ones in your L-2B these:
        A-2-100
        --or--
        F-318 ?
        BL-65 #1705
        TF #910
        EAA 1423
        Winterville, NC
          Yes.
            Here is a picture of the original 41 with the vents in the windscreens. They are the type Josh showed and since they are right at the leading edge high pressure area they pull in quite a bit of air. The disadvantage is if you mess up a hole, you ruin the windscreen. Nice thing is the 4 piece windscreens are pretty easy to make new pieces. I REALLY wouldn't want to ruin a blown post war windscreen and I think that is why people put them in the door window.
              Which ones, Hank? The ones that rotate with the knob or the one that the whole vent swivels?
                I put them in the top front of the side slider window on the F-19 an other good spot is the original place on the boot cowl , provides cooler air up from your legs.
                  The original ones were the ones with the knob. I don't know when the "shaped" ones came out but forming plexi was developed in WW-II for canopies. The knob ones are made from flat pieces of Plexi with one piece bent about 45* that rotates to expose the half hole.
                  I flew in a plane with them in the boot cowl and they really do bring a LOT of cool air in around your legs. If you have an uninsulated fire wall they are a BIG help!
                    Thanks, Hank. That's the picture I was looking for.
                    Josh
                    BL-65 #1705
                    TF #910
                    EAA 1423
                    Winterville, NC
                      Hank ,These are some original vents from my Dad's 41 Deluxe and look like the ones in the picture you posted - the vista vents are similar but thought you might be interested in them for the 4 piece windshield you are building.- They were made from very thin material and have about fallen apart but one of them could still be used for a pattern and some day when I decide to recover my 41 I was thinking of trying to make some new ones -Not sure how the scoops were formed -may be heat formed? If anyone has any ideas about making them please let me know.
                      Buell
                      Buell Powell TF#476
                        Buell,
                        Those scoops appear to be made of celluloid.
                        If that is the case, the flat stock could be soaked in solvent and pressed into a mold, then the opening in the scoop would be cut out.
                        Best Regards,
                          It looks like we might be able to glue the pieces back together and use epoxy/glass to reenforce the outside so a male mold can be made from the inside. Once the mold is cleaned up we can vacuum form new ones over it from PETG, glycol-modified polyethylene terephthalate copolyester (it is SO much fun to say things like that!) or Acrylic. We could use Polycarbonate (but it is hard to form) or celluloid (but it has low resistance to chemicals and UV).
                          I have a good local company that vacuum forms small parts if we have a mold.
                          If we make some, I want two!
                            Hi Mark,
                            I think you are right and being parked outside in the Texas sun is why my Dad had to replace them-he only had the plane for a year or 2. Hank--if you would like to borrow the vents to check with the company about vacuum forming some I could mail them to you-if enough of us are interested in a set then may be it wouldn't cost to much to have them made? Hadn't thought about those old vents in years but making or having some original style vents made would be nice.
                            Buell Powell TF#476
                              Buell , Yes I could put them back in your dads airplane !! Jim -owner of your dads airplane
