Moved from parts for sale, tie-down release gizmo.
OK, here I go with my school-teacher gene showing itself:
When do hand-propped airplanes run away and hit things?
When they are STARTED without being tied down at a throttle setting other than IDLE. You will notice it requires three conditions.
WHEN STARTING: I have NEVER heard of an airplane running away from a pilot when it was sitting there idling AFTER starting, absolutely never if it is chocked. I suppose you might bang the throttle getting in the door, but you should have a good grip on something by then and not get thrown out of the airplane.
THROTTLE OPEN: If you always turn the engine over backwards (slowly) to clear flooding it is very unlikely to fire, even if the mag switch is on or failed. Turning it backwards WILL clear the problem the same as forward and anybody that tells you otherwise is completely and totally mistaken. When you do this the airplane must absolutely be--
TIED DOWN: This only applies when you START the engine--that is ALWAYS when they run away. AFTER the airplane is started and idling you can safely untie the tail, remove the right chock, walk around the airplane and put the right chock in the airplane, remove the left chock and get in the airplane. If the airplane creeps a little when you remove the left chock, you can restrain it a bit with your body until you get your foot on the step.
I have used this technique for 30 years on 3 Taylorcrafts and never had a problem, EVER, and every runaway incident I know of (4) violated one or more of these rules.
You don't need a remote release. Just be sure it is ALWAYS tied down and chocked when you START IT, especially when you are clearing a flooded condition, and anytime you pull the engine through.
By the way, though I am not positive about this, I suspect anytime you start the engine without someone at the controls your liability insurance is null and void and you will be the one who pays for damages. I base this opinion on the fact that aircraft insurance companies will generally do anything they can to avoid paying a claim.
