trim tab link
  • trim tab link
    I need the link between trim tab and elevator. Or a picture. George
    Re: trim tab link
    Still looking. george
      Re: trim tab link
      I have one I can make a picture of for you and measurements.
        Re: trim tab link
        Thanks. George
          Re: trim tab link
          One of these components?
            Re: trim tab link
            That's it. The rod from bell crank to trim tab. George
              Re: trim tab link
              With a drawing you should be able to make it as an owner produced part. I have one for my 45 that is not mounted if you need dimensions or a drawing and I think there may be some damaged elevators at the airport that might have one. If you get a used one make sure the holes are all snug fits to the bolts. No sense putting extra play into the trim system.
                Re: trim tab link
                Thanks for the help. Got one to copy. George
                  Re: trim tab link
                  I have more play in the trim tap when I like to have.
                  It appers what I have to redo the fabric to get to inner workings of the trim system, would it be possible to add a spring in the system to take up the play.
                  I fly with slight forward pressure to fly level.
                  In regards to the picture of trim mechanisim shown above: Is it taken from bottom or top of the evelevator.
                  I dont see the oil hole in the screw!
                  Len
                  Foundation Member # 712
                    Re: trim tab link
                    The picture is a top view.
                      Re: trim tab link
                      Here's the lub hole.
                        Re: trim tab link
                        Ahhh,|Thank fellows, I do oil mine 3- 4 times a year, but I dint know there it in the realation to the wire wheel.
                        Len
                          Re: trim tab link
                          Speaking of the oil hole for the trim jackscrew, I have a tip for you all.
                          Everytime I check my oil, I take the dipstick and touch it to the oil hole on the elevator before I wipe it off to check the oil. It only takes a second, and when I taxi for takeoff, I crank the trim a few turns in each direction to feed the oil droplet into the sleeve where the screw rides.
                          No more pliers, wrenches and cussing trying to free up a stubborn shaft.
                          John 3728T
